![]() | Home > Faults & Fixes > TDV8 Hesitation on acceleration |
Tony666 Member Since: 27 Jul 2011 Location: Barry Posts: 170 ![]() ![]() |
Sounds like it could be the EGR valves. Lots of info on this site, common problem......I had the same symptoms, bought a blanking kit for less than a tenner, been fine ever since.... |
Chilly07 Member Since: 25 Dec 2015 Location: Central Coast, NSW Posts: 24 ![]() ![]() |
Hi tony,
Ah apologies then, I've got the tdv6 so not sure about the tdv8. Maybe it was a typo on your post but you need to search for EGR not EGO |
yes....good old spell check/changer...did mean EGR! |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9153 ![]() ![]() ![]() |
Mine does this too. It feels like good old fashioned 1980s turbo lag. My gearbox is being reconned at the moment so will let you know if it's different after that. If not, it would point to the EGRs. These can be blanked but need a software update too. 2012 SDV6 - it's missing a couple of cylinders
johnsporttdv8 Member Since: 02 Nov 2014 Location: Cambridgeshire Posts: 16 ![]() ![]() ![]() |
If its any consolation my MY2010 AB has done this from the day I picked it up from the dealer new. Very disappointing. Its only the sound of the TDV8 that keeps me smiling. |
Mine does not always do it and seems to of recently cured itself? |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 961 ![]() ![]() ![]() |
Not easy to blank V8 egr's,, software update also required I think, someone posted just the other week it was just as cheap to have 2 new valves as against blanking and software.
Stuart02 Member Since: 31 May 2016 Location: Melbourne Posts: 2 ![]() ![]() |
Hey there, just wondering how your car's going after it's gearbox recon? Cheers |
