Home > Faults & Fixes > TDV8 Hesitation on acceleration
Chilly07
Australia
TDV8 3.6 2008 RRS. Engine warmed up
I get a hesitation on acceleration. A little bit difficult to repeat. Sometimes a strong hesitation sometime not.
Also when I put my foot down to accelerate hard, I hear the exhaust note change but it is not constant...feels like it is holding back.
Thoughts/advice please.
Chilly
Post #488968 Thu Feb 25 2016 11:55pm
Tony666
2005 Range Rover Sport TDV6 HSE Bonatti Grey
Sounds like it could be the EGR valves. Lots of info on this site, common problem......I had the same symptoms, bought a blanking kit for less than a tenner, been fine ever since....
Post #488969 Fri Feb 26 2016 12:01am
Chilly07
Australia
Hi tony,
did not think you could get the kits for the TDV8?
Have looked for this issue under ego's but Censored if I can find it!!
Chilly
Post #488972 Fri Feb 26 2016 12:14am
Tony666
Ah apologies then, I've got the tdv6 so not sure about the tdv8. Maybe it was a typo on your post but you need to search for EGR not EGO Very Happy
Post #488973 Fri Feb 26 2016 12:22am
Chilly07
Australia
yes....good old spell check/changer...did mean EGR!
Post #488974 Fri Feb 26 2016 12:23am
Mine does this too. It feels like good old fashioned 1980s turbo lag. My gearbox is being reconned at the moment so will let you know if it's different after that. If not, it would point to the EGRs. These can be blanked but need a software update too. 2012 SDV6 - it's missing a couple of cylinders
Post #489010 Fri Feb 26 2016 11:21am
johnsporttdv8
United Kingdom 2010 Range Rover Sport TDV8 Autobiography Alaska White
If its any consolation my MY2010 AB has done this from the day I picked it up from the dealer new. Very disappointing. Its only the sound of the TDV8 that keeps me smiling.
Post #494059 Thu Apr 21 2016 1:04am
Chilly07
Australia
Mine does not always do it and seems to of recently cured itself?
Post #496236 Tue May 17 2016 2:17am
gogsy1956
Not easy to blank V8 egr's,, software update also required I think, someone posted just the other week it was just as cheap to have 2 new valves as against blanking and software.
Mine. Also hesitates at times, I'm sure this has to do with it staying in second gear when you pull up at lights etc,, try selecting N then drive again to put it into first gear and see if you notice a difference 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #496269 Tue May 17 2016 11:24am
Stuart02
Australia
Hey there, just wondering how your car's going after it's gearbox recon?
Post #497443 Tue May 31 2016 11:45am
