![]() | Home > Technical > Knocking noise |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2021 ![]() ![]() |
A suspension bush probably......get a good independent LR garage to take a look..... * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Jaggs Member Since: 09 Aug 2015 Location: Leeds Posts: 259 ![]() ![]() ![]() |
Noise on uneven road is often ARB bushes, noise when braking often lower arm bushes but you won't know for sure until some one gets underneath it, got a knock myself that needs looking at. Nanocom Evo |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 ![]() ![]() ![]() |
Will be front lower arm rear bushes,most people say just change the whole arm complete , one I've done I've change just the bushes. The jibes the same in as much you need to remove the arm which normally means cutting through the rear bolt unless your very lucky then replace the arm or bush. If I'm using the same arm I mark up the bolts which have offset cambers then when I refit the arms, alone the bolts in the same place, saves having to get a 4 wheel alinement done. Never had any problems with tyre wearing off or pulling etc.. 2008 G4 RRSport TDV8 current
Cosmo15555 Member Since: 24 Jun 2014 Location: Stevenage Posts: 163 ![]() ![]() ![]() |
Thanks for the info I will get it checked out |
Good reference for part costs
Has any one used the advanced factor front ARB bushes, about to order some but undecided whether to just buy genuine Landrover Nanocom Evo |
Bought some of those but compared them with the LR part and decided not to fit them. You decide. 2008 MY Java Black TDV8 HSE
Get the Land Rover ones, might cost a little bit more but will prob last twice as long.. 2008 G4 RRSport TDV8 current
Result, found genuine front ARB bushes, new brackets and all replacement Bolts on eBay for £70 plus delivery from Hunters main dealers in York, called to ask them if they could get them to me for the weekend as they are 30 miles away and wanted to make sure the post would get them here. Parts guy takes address and says one of our technicians lives near there I'll ask if he'll drop them off for you on way home which he did, spot on service and great price. Nanocom Evo |
Had car checked both lower arms rear bushes are very soft what's best result changing rear bushes or new arms
Stick with Genuine.... * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Considering changing bushes has anybody used poly bushes |
No experience of poly bushes, heard they last longer but the ride not as smooth Nanocom Evo |
As I said above change a few bushes only ever used gen.. 2008 G4 RRSport TDV8 current
