Home > Technical > Knocking noise
Cosmo15555
United Kingdom 2010 Range Rover Sport Supercharged HSE Stornoway Grey
Knocking noise
When I drive up to 10mph and go over uneven surface I get a knocking noise coming from the front
I also get same noise at same speed if I stab at the brakes
Any help would be appreciated
Cosmo
Post #486864 Sun Feb 07 2016 8:32pm
DrRob
A suspension bush probably......get a good independent LR garage to take a look..... * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #486866 Sun Feb 07 2016 8:36pm
Jaggs
Noise on uneven road is often ARB bushes, noise when braking often lower arm bushes but you won't know for sure until some one gets underneath it, got a knock myself that needs looking at. Nanocom Evo
Post #486871 Sun Feb 07 2016 8:57pm
Camelrock
Will be front lower arm rear bushes,most people say just change the whole arm complete , one I've done I've change just the bushes. The jibes the same in as much you need to remove the arm which normally means cutting through the rear bolt unless your very lucky then replace the arm or bush. If I'm using the same arm I mark up the bolts which have offset cambers then when I refit the arms, alone the bolts in the same place, saves having to get a 4 wheel alinement done. Never had any problems with tyre wearing off or pulling etc.. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #486897 Sun Feb 07 2016 11:29pm
Cosmo15555
Thanks for the info I will get it checked out
Post #486948 Mon Feb 08 2016 9:01pm
DrRob
Good reference for part costs
http://www.advancedfactors.co.uk/steering-...0-22-c.asp
Sometimes cheaper to replace a complete arm than mess about on individual bushes Thumbs Up
Call them for advice Thumbs Up * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Post #486950 Mon Feb 08 2016 9:56pm
Jaggs
Has any one used the advanced factor front ARB bushes, about to order some but undecided whether to just buy genuine Landrover Nanocom Evo
Post #487010 Tue Feb 09 2016 6:56pm
Paddi
Bought some of those but compared them with the LR part and decided not to fit them. You decide. 2008 MY Java Black TDV8 HSE
Post #487036 Tue Feb 09 2016 10:26pm
Camelrock
Get the Land Rover ones, might cost a little bit more but will prob last twice as long.. 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #487051 Wed Feb 10 2016 12:08am
Jaggs
Result, found genuine front ARB bushes, new brackets and all replacement Bolts on eBay for £70 plus delivery from Hunters main dealers in York, called to ask them if they could get them to me for the weekend as they are 30 miles away and wanted to make sure the post would get them here. Parts guy takes address and says one of our technicians lives near there I'll ask if he'll drop them off for you on way home which he did, spot on service and great price. Nanocom Evo
Post #487102 Wed Feb 10 2016 8:25pm
Cosmo15555
Had car checked both lower arms rear bushes are very soft what's best result changing rear bushes or new arms
Anybody used lower arms from britpart as been quoted good price for them
Post #487161 Thu Feb 11 2016 6:15pm
DrRob
Stick with Genuine.... * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Post #487179 Thu Feb 11 2016 8:02pm
Cosmo15555
Considering changing bushes has anybody used poly bushes
Post #487191 Thu Feb 11 2016 9:15pm
Jaggs
No experience of poly bushes, heard they last longer but the ride not as smooth Nanocom Evo
Post #487195 Thu Feb 11 2016 9:25pm
Camelrock
As I said above change a few bushes only ever used gen.. 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #487266 Fri Feb 12 2016 2:14pm
