Home > Faults & Fixes > Groaning noise from front |
alpaca Member Since: 09 Sep 2014 Location: Silicon Valley Posts: 83 |
If you still have warranty take the dealer service manager for a ride to listen to the noise. Could be exhaust, diff, wheel bearing or a number of other things. Wheel bearing should make more noise when you turn to one side (more load on that wheel). |
Tue Jan 12 2016 7:36am |
Jonesyg10 Member Since: 19 Oct 2015 Location: Stockholm Posts: 3 |
Well I did some more investigating and the noise is only apparent in 5th gear at 1500rpm, it is at the garage now so will let you know what it turns out to be for any one else getting this noise. |
Sun Jan 17 2016 3:06pm |
Ned Member Since: 25 Jul 2015 Location: London Posts: 100 |
I have a groaning noise also it's called the missis don't stop either 😂😂. |
Fri Jan 29 2016 11:39am |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
Hats off to you Ned either very brave got balls of steel, your Mrs doesn't read the threads or you like the spare bed room 2008 G4 RRSport TDV8 current
Fri Jan 29 2016 2:24pm |
