Home > Maintenance & Modifications > EGR blanking
SRE
Spain
Remember, with a remap, you don't use all the extra power that much, only overtaking etc, however the drivability with a remap is another subject altogether. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #483038 Mon Dec 21 2015 1:17pm
Lost for Words
SRE wrote:
Your trans id designed to take the V8, so a 2.7 is not an issue
It can be if the transmission is not healthy though. Even with a healthy box, a bad remap could cause damage - it's about power and torque delivery, rather than outright power/torque. Thumbs Up Visiting from DISCO3.CO.UK
Post #483040 Mon Dec 21 2015 1:32pm
SRE wrote:
Your trans id designed to take the V8, so a 2.7 is not an issue,
Actually the gearbox in the SC is upgraded slightly to handle the power. Having said that, a 2.7 with a map isn't going to getting anywhere near the standard gearbox's threshold. 2012 SDV6 - it's missing a couple of cylinders
Post #483068 Mon Dec 21 2015 7:58pm
Lost for Words
The SC does have the speed, but the torque of the TDV8 will put the gearbox under the most strain. It's the torque delivery of a badly remapped diesel that can be the real killer. Thumbs Up Visiting from DISCO3.CO.UK
Post #483097 Tue Dec 22 2015 9:49am
SRE
Spain
As I said, have a chat to Pete Bell at BAS, he will not lead you down the wrong path. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #483109 Tue Dec 22 2015 1:45pm
Yes, the 6HP26 has an input torque of 650Nm. The TDV8 has 640Nm as standard. No doubt the 'box has a factor of safety built in and can actually handle twice that but we'll never know.
I wonder if LR fitted the same uprated gearbox to the TDV8 as on the SC... 2012 SDV6 - it's missing a couple of cylinders
Post #483120 Tue Dec 22 2015 6:47pm
