Home > Maintenance & Modifications > CH3M-14293-BA Day Time Running Lights.
the_big_1
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Fuji White
Hi Guys,
Does anyone know if the daytime running lights kit will fit an autobiography bumper?
Post #481763 Sun Dec 06 2015 3:26pm
ABSport
Yes the genuine LR set will. They go in the bottom corners where the plastic wavey squares are, ( just above the silver toe eye cover )
They have to be cut out to be able to fit Thumbs Up
Post #481764 Sun Dec 06 2015 3:41pm
the_big_1
Do they replace all the grille wavey part do you know?
Post #481765 Sun Dec 06 2015 3:46pm
ABSport
Yes they fit in that part, however the LED's are a horizontal strip. Thumbs Up the rest is just smooth black plastic.
Post #481766 Sun Dec 06 2015 3:48pm
the_big_1
Great stuff!
I have the instructions but no where does it mention cutting out the mesh looching part.
Do you cut out the whole mesh part, useing the outer edge as a guide?
Post #481767 Sun Dec 06 2015 3:49pm
ABSport
I'm not sure I only see a Autobiography with them fitted not sure if they are genuine or aftermarket.
I have a picture below
In the picture it looks like replacement grill section Shocked
Post #481768 Sun Dec 06 2015 3:59pm
ABSport
You may be able to just cut out the LED strip section. See below.
Post #481769 Sun Dec 06 2015 4:01pm
the_big_1
I want to replace the whole grille part as mine is damaged.
I wounder if there is a way to find out as the instructions dont say anything about cutting the bumper, on the rear to fit the bracket.
Post #481770 Sun Dec 06 2015 4:06pm
ABSport
The first picture I put up clearly shows the square sections which clip in. You may have to ask LR or someone who has fitted them may know.
Post #481771 Sun Dec 06 2015 4:09pm
the_big_1
Do you think its possible to buy parts from the kit seperate? I.E the cover and the brackets?
Post #481773 Sun Dec 06 2015 4:30pm
PEACHY
Pretty sure the AB DRL's are a different part number Thumbs Up 16MY Estoril Blue SVR.............
Post #481798 Sun Dec 06 2015 9:00pm
I think VPLSV0065 For A/B and VPLSV0064 is Standard Bumper.
http://www.ebay.co.uk/itm/Range-Rover-Spor...42KxzT9rpg
http://www.ebay.co.uk/itm/Range-Rover-Spor...N6TQrpHS-A
Post #481800 Sun Dec 06 2015 9:22pm
Buckster
64-standard bumper
65-autobiography bumper
Thumbs Up 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #481818 Sun Dec 06 2015 11:02pm
the_big_1
Looks like the same instructions for both.
Need details of how the front is cut out correctly on AB
Post #481833 Mon Dec 07 2015 8:21am
