![]() | Home > Maintenance & Modifications > CH3M-14293-BA Day Time Running Lights. |
the_big_1 Member Since: 04 Jul 2014 Location: Warwickshire Posts: 577 ![]() ![]() ![]() |
Hi Guys,
Do they replace all the grille wavey part do you know? |
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 ![]() ![]() ![]() |
Yes they fit in that part, however the LED's are a horizontal strip. |
Great stuff!
I'm not sure I only see a Autobiography with them fitted not sure if they are genuine or aftermarket.
You may be able to just cut out the LED strip section. See below.
I want to replace the whole grille part as mine is damaged.
The first picture I put up clearly shows the square sections which clip in. You may have to ask LR or someone who has fitted them may know. |
Do you think its possible to buy parts from the kit seperate? I.E the cover and the brackets? |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2796 ![]() ![]() |
Pretty sure the AB DRL's are a different part number |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5139 ![]() ![]() ![]() |
I think VPLSV0065 For A/B and VPLSV0064 is Standard Bumper.
Looks like the same instructions for both.
