Home > Technical > Fixed.Almost no response on throttle when cold RRS 2.7 2006.
41664166@online.no
Norway 2006 Range Rover Sport TDV6 Autobiography Rimini Red
Almost no response on throttle when cold RRS 2.7 2006,.. HELP!
Hi, my RRS Sport 2.7 2006 Diesel is "dead" when cold, almost impossible to drive,
almost no response when I press the pedal...
When i get abit boost it is a little bit better.
Gradually better response when the engine gets hotter, and when normal temp it run like normal...
No warninglight in dashboard.
What can i do to fix this?
TrondL
Last edited by 41664166@online.no on Sat Apr 02 2016 8:03am. Edited 1 time in total
Post #481736 Sun Dec 06 2015 7:09am
Disco_Mikey
Blank your EGRs Thumbs Up
Post #481737 Sun Dec 06 2015 8:42am
41664166@online.no
How ?
Do you have any suggestions on what kit I should buy then ?
TrondL
Post #481741 Sun Dec 06 2015 9:43am
Disco_Mikey
Pair of plates on eBay for £6-7 or so Thumbs Up
Post #481746 Sun Dec 06 2015 10:11am
41664166@online.no
And no programming is needed for installation of these
Post #481750 Sun Dec 06 2015 10:45am
Lost for Words
No, not on an 06MY. Thumbs Up Visiting from DISCO3.CO.UK
Post #481753 Sun Dec 06 2015 10:56am
41664166@online.no
I do understand ... then I just order a kit and get EGR removed.
Thanks to you guys
Do you have a link to where I can read about the job and assemble this kit
Post #481754 Sun Dec 06 2015 11:02am
Lost for Words
Take a look here: http://www.disco3.co.uk/gallery/albums/use...0SMALL.pdf Wink
Some kits, like the one in the guide, have four plates and the pipes are removed, others use just two and the pipes are left in place - either will do the job. Thumbs Up Visiting from DISCO3.CO.UK
Post #481756 Sun Dec 06 2015 11:13am
41664166@online.no
What will then happen to the exhaust values, ..
Will I get in trouble by approvals by EU control
TrondL
Post #484201 Thu Jan 07 2016 4:57am
Lost for Words
That's a good point actually - not sure on your testing etc. over there but I think you may do.
If that is indeed the case, you can get emulators from BAS that will allow the valves to be seen to be working to disgnostics, or, should you decide to replace the valve(s), you could still blank them (keeping the pipes in place) and it would not be an issue as long as the valves are working.
Post #484206 Thu Jan 07 2016 10:59am
41664166@online.no
How do I get in touch with BAS
Post #484211 Thu Jan 07 2016 11:24am
Lost for Words
http://bellautoservices.co.uk/
web@bellautoservices.co.uk
+44 845 108 2815
Post #484212 Thu Jan 07 2016 11:49am
41664166@online.no
Today when we started the car the battery waring light was there for a minute before it disappeared.
No response on throttle for a minute.
After 1 miniute everything works fine again,...
Could this have any connection ?
Ps: Have ordered a blanking kit for the EGR
Exciting too see if thats is all it takes
TrondL
Post #484704 Thu Jan 14 2016 5:13am
Lost for Words
Can't see that the battery light would be related, but do check the voltages. Thumbs Up Visiting from DISCO3.CO.UK
Post #484717 Thu Jan 14 2016 10:40am
41664166@online.no
Still no throttle respons RRS 2.7 2006,..
Hello again
Mounted this EGR Blanking Kit this weekend ,.
https://secure.bellautoservices.co.uk/store/egr-blanking/
But this morning it was the same previously symtons
Almost no response when I press the pedal for 30 sec,..
After 30 sec everything ok,..
Anyone have any idea what it might be for faulty ???
Regards TrondL
Post #486246 Mon Feb 01 2016 5:26am
