Home > Technical > Fixed.Almost no response on throttle when cold RRS 2.7 2006.
41664166@online.no
Norway 2006 Range Rover Sport TDV6 Autobiography Rimini Red
Hello again
Mounted this EGR Blanking Kit this weekend ,.
https://secure.bellautoservices.co.uk/store/egr-blanking/
But this morning it was the same previously symtons
Almost no response when I press the pedal for 30 sec,..
After 30 sec everything ok,..
No warninglight in dashboard.
Anyone have any idea what it might be for faulty ???
Regards TrondL
Post #486422 Wed Feb 03 2016 4:46am
41664166@online.no
Anyone have a idea her ???
Post #488033 Fri Feb 19 2016 4:37am
Lost for Words
Could be a seized turbo actuator. You should find threads on freeing it with a search on Disco3. Thumbs Up Visiting from DISCO3.CO.UK
Post #488053 Fri Feb 19 2016 9:18am
41664166@online.no
Can`t find info about it
Post #488088 Fri Feb 19 2016 1:41pm
Lost for Words
Few threads here:
http://www.disco3.co.uk/forum/topic128091.html
http://www.disco3.co.uk/forum/topic122113.html
http://www.disco3.co.uk/forum/topic96899.html
http://www.disco3.co.uk/forum/topic99198.html
Diagnostics might be able to give more insight. Thumbs Up Visiting from DISCO3.CO.UK
Post #488093 Fri Feb 19 2016 2:11pm
41664166@online.no
Still the same problem,..
No throttle for 20 sec after start of the car.
No fault codes when i scans the diagnostics
TrondL
Post #489951 Fri Mar 04 2016 4:29am
UK Guy
England 2013 Range Rover Sport SDV6 Autobiography Santorini Black
I had that issue on a Alfa I used to own.
It was the air flow meter, not sure if this help though.
Normally if you unplug them the car should run, if better than it was replace it.
Worth a look RRS HSE with a few extras & a
2013 RRS Autobiography
Post #490197 Sun Mar 06 2016 9:04pm
41664166@online.no
Now it is fixed
Used CRC Air Sensor Clean on the air flowmeter
Now the car runs properly and also have full throttle at the start-up
TrondL
Post #492466 Sat Apr 02 2016 6:53am
erickwan
Malaysia
Worth a look
I have 2 Alfas and 2 LR's. No such problems with the Alfas, but I have this problem with my Freelander 2.
Wonder if I would dare take a risk by spraying the MAF with switch cleaner...........a new FL2 MAF sensor is well over £130.
Post #492636 Mon Apr 04 2016 2:16am
UK Guy
I cleaned one once with an ultrasonic cleaner (connector out of the cleaning solution) which worked great.
I think as long as you don't touch the internals with any object )it as it very fragile) a cleaner spray of some sort should be fine as long as it totally evaporates and dry before you plug it in. RRS HSE with a few extras & a
Post #492878 Tue Apr 05 2016 9:57pm
UK Guy
41664166@online.no wrote:
Now it is fixed
TrondL
That's great you sorted it. RRS HSE with a few extras & a
Post #492879 Tue Apr 05 2016 9:59pm
