Home > Maintenance & Modifications > Rear diff drain plug
Morgi27
Hi guys
Changing the diff and trans fluids on my 55 06 sport Done the front and trans box fluids but when I come to do the back
Diff the drain plug seems to be smaller than a 3/8 square and too big for next size down thought it might be rust/crap in there but wire brushed it and 3/8 is still too big? Any one else had this problem??
Post #480273 Wed Nov 18 2015 2:13pm
Disco_Mikey
14mm hex Thumbs Up
Post #480275 Wed Nov 18 2015 2:34pm
Morgi27
Thanks for the reply
It's not a hex plug it's square drive but 3/8 is too big
Post #480281 Wed Nov 18 2015 3:33pm
Lost for Words
Very odd. Perhaps someone could have put a non-standard plug in, but even then, who on earth would make one between a 3/8 and 1/4 square drive? Confused
Have you tried a thump with a hammer?
Thumbs Up Visiting from DISCO3.CO.UK
Post #480286 Wed Nov 18 2015 3:42pm
Morgi27
That's only thing I can think of its been replaced with different size drive It's not 3/8 inch too small !!
Any ideas how I get it out and when/if I do,I'd like to replace it to 3/8 or hex drive
Where can I get one from guys?
Post #480289 Wed Nov 18 2015 3:50pm
myfirstrrs
You take a 3/8 extension and carefully grind it down on each flat until it fits. It needs to fit snuggly and if you have a slight taper (thinner at the end) you can also tap it in to make it tighter. Gently turn with a t-bar or ratchet and hopefully it will loosen.
A firm tap before you start might make it easier.
Post #480290 Wed Nov 18 2015 4:22pm
Morgi27
Excellent I'll give that a shot ASAP
Cheers fellas
Post #480292 Wed Nov 18 2015 4:42pm
Disco_Mikey
Any chance of a picture. Sounds very, very odd
Post #480328 Wed Nov 18 2015 8:08pm
Morgi27
Got a pic yes but it wont upload for some reason!!
I've grinded down a 3/8 inch extension and it fits fine now
Only thing I can think of with the drain plug is it's pretty corroded and maybe that's
Stopping the 3/8 inch drive from going in has the outer part of the drain plug is flaking away aswell
Anyway a I hope it comes out ok when I try
Would like to fit new ones in the rear diff if anyone can put me in right direction to buy them ??
Thanks
Post #480331 Wed Nov 18 2015 8:42pm
http://www.advancedfactors.co.uk/3-rear-axle-unit-1796-c.asp Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #480333 Wed Nov 18 2015 8:50pm
