![]() | Home > Maintenance & Modifications > Rear diff drain plug |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4527 ![]() ![]() ![]() |
14mm hex |
Morgi27 Member Since: 31 Jan 2015 Location: Birmingham Posts: 88 ![]() ![]() ![]() |
Thanks for the reply
Very odd. Perhaps someone could have put a non-standard plug in, but even then, who on earth would make one between a 3/8 and 1/4 square drive? |
That's only thing I can think of its been replaced with different size drive It's not 3/8 inch too small !!
myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433 ![]() ![]() |
You take a 3/8 extension and carefully grind it down on each flat until it fits. It needs to fit snuggly and if you have a slight taper (thinner at the end) you can also tap it in to make it tighter. Gently turn with a t-bar or ratchet and hopefully it will loosen.
Excellent I'll give that a shot ASAP
Any chance of a picture. Sounds very, very odd |
Got a pic yes but it wont upload for some reason!!
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9144 ![]() ![]() ![]() |
http://www.advancedfactors.co.uk/3-rear-axle-unit-1796-c.asp |
