Home > General (L494) > Active Exhaust Option?
Tim in Scotland
Just been looking something about the e-diffs and as you do I found a chaprter about the Active Exhaust system (Page 108)- the same system as Jaguar fits as an option to the F Type Jags so you can have a loud exhaust or a fire spitting and deafening exhaust at the press of a button! I assume these are an option on the V8 S/C and SVR but I have never seen the check box for it on the configuator or when going through a spec with the dealer so is it an option in the UK or a bit of LR mis-information? If you have it fitted then the DSC on/off button on the centre consol is the same size as the Lo range switch and the Active Exhaust switch is where the "missing" half of the DSC switch should be. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #478989 Fri Nov 06 2015 4:23pm
philmw
United Kingdom 2012 Range Rover Sport Supercharged Sumatra Black
I believe - not an option, only standard on SVR. SVR can't have the off-road cruise control (whatever it's called) for this reason.
Post #478992 Fri Nov 06 2015 5:19pm
Mark_N
Isn't it simply the fact that the button position is taken up with the sports exhaust button which means there is nowhere for the off-road cruise control button to go plus, I assume, whatever software is used to act on that button push is different between the SVR and other cars. Mark
SVR in Estoril Blue Thumbs Up
Post #478999 Fri Nov 06 2015 6:43pm
DaveW
Tim, Phil and Mark are both correct. We don't sell active exhaust on non SVR cars.
Post #479001 Fri Nov 06 2015 6:51pm
Disco
Startech do an active exhaust for the 2014 Supercharged.
I have tried to paste a linK to Youfftube but no luck.
Prepare to have movement in your pants when you play the clip!!!
Post #479020 Fri Nov 06 2015 8:21pm
philmw
This one -
Prefer this -
Post #479025 Fri Nov 06 2015 9:07pm
Tim in Scotland
Thanks guys, it's interesting that my 2015MY Handbook is so up todate as my car was built on March19th this year! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #479026 Fri Nov 06 2015 9:21pm
Disco
philmw wrote:
This one -
Prefer this -
Have a look at the JE motors site and look for RRS tuning.
Post #479030 Fri Nov 06 2015 9:46pm
