Home > General > SDV6 Hesitation when setting off
a3hy
United Kingdom 2012 Range Rover Sport SDV6 HSE Fuji White
I have a 2012 SDV6 and have noticed the often talked about lag which i can live with, its usually just when its between gear changes. However just recently its doing something different.
When i am pulling away from traffic lights from a standstill and just setting off nice n steady about a second in from moving off the car feels like i have taken my foot of the accelerator, and just dies on me (engine still running) it then thinks about it for a second or two and then just carries on normally, it did it 4 times last night on a 5 mile journey.
The manufacture warranty has just expired but i did take out full land rover extended warranty with land rover assist, is it just a case of ringing them and they get things organised? Also when you have extended warranty do they cover the original diagnostics charge (if it turns out to be a part which is covered) or is it just the cost of the part + fitting.
Anyone any experience with this, I've left my warranty booklet at work, i will have a read on Monday too.
Post #478395 Sun Nov 01 2015 11:03am
Talk to your dealer and see if there are any gearbox software updates outstanding on your vehicle. My 2012 had 2 gearbox software updates to try and combat the delayed throttle response. Other than that, start using the paddle shift and knock it down to 1st gear when setting off. Your vehicle has a default setting to set off in 2nd gear from standstill. It's just the way JLR have programmed RRS. Whistle
Post #478399 Sun Nov 01 2015 1:12pm
muddywheels
Milk Float Man
The gap between throttle and brake is very small and I found when wearing boots if you touch side of brake pedal while accelerating this happens - LR appears to have designed pedals for ladies feet not men Rolling Eyes Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #478492 Mon Nov 02 2015 10:14am
a3hy
Update:
Rang the dealer today and they said whilst i have an extended warranty then the best thing is to ring Land Rover Assist.
Did that and told them there was no big emergency but they came out within 2 hours, he plugged it and no faults stored. he did say they have had a few of these with crank shaft sensors faulty and so he made a call and bumped me up the dealer Que.
Assist rang back and said drop it off in the morning and i could pick up a discovery to use which surprised me as i didn't think you got a car on extended warranty for the first few days.
Good service so far, just hope they find something as its getting a bit annoying.
Post #478551 Mon Nov 02 2015 6:57pm
a3hy
Good point, and i did have new boots on that day, i hope its not something as stupid as that or i will look like a right ***
Post #478552 Mon Nov 02 2015 6:59pm
DrRob
How much was the extended warranty from LR as a matter of interest? * Current: 2024 D350 Defender 90 on coils!
* Current: 1974 Lightweight 2.25L petrol. Old skool
* GONE: 2012 RR Sport HSE SDV6 Orkney Grey. Now being piloted by RRSTDV8
I use www.glenrands.co.uk Great independent specialist!
Post #478635 Tue Nov 03 2015 1:16pm
Mine was around £1200 for the top warranty, which includes a claim limit upto the value of the vehicle. It also includes other benefits which I can't recall at the moment.
There is a cheaper option. Around £790 ish, with a claim limit of £3000. But £3000 doesn't get you very much at a main dealer with their hourly rate. Laughing
Post #478636 Tue Nov 03 2015 1:37pm
a3hy
Got the car back today, great service once again from Guy Salmon at Knutsford.
It turned out to be the stop light switch faulty.
Been okay since i got it back. No quibbles with the extended warranty and i got a brand new discovery to use whilst mine was being repaired.
Post #478859 Wed Nov 04 2015 10:13pm
muddywheels
Milk Float Man
I had brake switch replaced about 3 times - showed up as fault so replaced but replacement was faulty too then replaced again because they didn't calibrate it and apparently couldn't be calibrated after it was fitted and used Rolling Eyes Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #478875 Wed Nov 04 2015 11:27pm
Just renewed mine Extended Warranty, Roadside Assistance and MOT £1095.00
Post #478876 Wed Nov 04 2015 11:29pm
