![]() | Home > General > SDV6 Hesitation when setting off |
a3hy Member Since: 21 Jul 2015 Location: Wigan Posts: 41 ![]() ![]() ![]() |
I have a 2012 SDV6 and have noticed the often talked about lag which i can live with, its usually just when its between gear changes. However just recently its doing something different.
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5642 ![]() ![]() |
The gap between throttle and brake is very small and I found when wearing boots if you touch side of brake pedal while accelerating this happens - LR appears to have designed pedals for ladies feet not men |
Update:
Good point, and i did have new boots on that day, i hope its not something as stupid as that or i will look like a right *** |
How much was the extended warranty from LR as a matter of interest? Visitor from fullfatrr.com
Mine was around £1200 for the top warranty, which includes a claim limit upto the value of the vehicle. It also includes other benefits which I can't recall at the moment.
Got the car back today, great service once again from Guy Salmon at Knutsford.
I had brake switch replaced about 3 times - showed up as fault so replaced but replacement was faulty too then replaced again because they didn't calibrate it and apparently couldn't be calibrated after it was fitted and used |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5091 ![]() ![]() ![]() |
Just renewed mine Extended Warranty, Roadside Assistance and MOT £1095.00 Cheers Col |
