Home > General (L494) > Which Engine SDV6 / SDV6 Hybrid / SDV8 / V8 Supercharged |
JSR2014 Member Since: 10 Feb 2015 Location: Kent Posts: 341 |
Ok,
Fri Oct 23 2015 11:13pm |
Renaco Member Since: 28 Jul 2011 Location: Bavaria Posts: 323 |
The Hybrid has no lag, in dynamic mode and start-stop in off position, it pushes away like hell.
Sat Oct 24 2015 1:19pm |
Mark_N Member Since: 09 Aug 2013 Location: London Posts: 1102 |
If I plan to drive (say), 12000 miles in my SVR, average MPG for the driving I do about 20, certainly no less and on a longer run, more. 600 gallons a year, 2725 litres, £3500 pa if you put super unleaded in it.
Sat Oct 24 2015 3:47pm |
I'm afraid you are mixing up torque and power. It's not torque which gets you up to speed, it's power. Mark SVR in Estoril Blue |
Sat Oct 24 2015 3:54pm |
gary3306 Member Since: 04 Feb 2015 Location: Northumberland Posts: 204 |
Its you who is wrong Mark. Torque 'AT THE WHEELS' gets you up to speed. Horsepower is only a made up figure derived from multiplying the torque figure with the RPM and dividing that by 5252. On arolling road, the HP is worked out from the torque being produced.
Sat Oct 24 2015 4:53pm |
parish Member Since: 15 Oct 2015 Location: Bucks Posts: 58 |
I have test driven both the SDV8 and SDV6. The only evidence of lag - if that's what is was - was on the V8 where I went to pull out of a junction and the car hardly moved. Luckily it was a quiet junction otherwise I would have been in the doodoo.. The salesman actually suggested it was my driving as I did not push the peddle hard enough he said...tosser. I think it was in the wrong gear personally as I had not come to a complete stop before trying to pull away. To be honest didn't notice any problems on the SDV6.
Sat Oct 24 2015 4:56pm |
R444SPT Member Since: 20 Mar 2015 Location: Offroad somewhere Posts: 217 |
So having driven an SDV8 for seven months and now temporarily in an SDV6, I will be very pleased to go back to the SDV8.
Sat Oct 24 2015 5:01pm |
GJW1 Member Since: 19 May 2015 Location: UK Posts: 447 |
This explains the problem well you don't come to a stop as there is space to pull out but the car I think isn't in the correct gear it's not all the time thoug only sometimes maybe 25% so depends on the throttle pedal position and various other factors however it isn't a nice feeling and if I can avoid it with a engine upgrade in my new order I'm tempted to do it. |
Sat Oct 24 2015 5:16pm |
Or maybe I could explain easier using the Bugatti Veyron as an example. Car has a top speed of about 210mph and a 0-60 time os about 2.5 seconds. It produces 922lb/ft of torque and has 1006BHP or thereabouts (derived from the torque figure)
Sat Oct 24 2015 5:21pm |
Big-Daddy Member Since: 06 Jun 2015 Location: Nottingham Posts: 19 |
I've driven the V6, V8 and SC, and the first RRS2 I had was the SC which was great fun, but I switched to the V8 4.4 because when your towing 3 tonnes across a muddy field there really isn't any other option in my opinion.
Sat Oct 24 2015 8:13pm |
You say refined is it really ? My dealer doesn't have one in and not one close so I can't test one but another thing on my mind is the noise been intrusive to the almost silence the car has when cruising in my sdv6. |
Sat Oct 24 2015 9:08pm |
Having driven all three, I would say the petrol engine is thE smoothest,
Sat Oct 24 2015 9:30pm |
Yes, I missed the comment that Renaco was referring to diesels only. The only difference between a car at 60 and a car at rest is the one at 60 has kinetic energy. It follows that the greater the ability of the car to create that kinetic energy, the faster it will be. The kinetic energy comes from the power of the engine (Power in Watts = 2* PI * Engine Speed (revs per second) * Engine Torque (newton metres)) so that it's both the engine speed and engine torque which has a bearing on the performance. Ignoring losses, an SVR accelerating to 60 mph in 4.5 seconds is averaging around 200 kW or about 270 bhp. An SDV8 has higher torque than an SVR but is slower to 60 because its peak engine speed and therefore power developed is lower. Once up and running, the engine speed can be matched - more or less - to the speed of the wheels through the transmission but at low speeds, there has to be some slip in the transmission - clutch or torque converter - to allow the engine to run at a viable speed while the road wheels are close to stationary. That's the great advantage of electric motors - their torque is generated even if the motor is stalled and the additional torque contribution contributes to a better take off from standstill. That's why the Tesla electric cars are achieving such spectacular standing start performance figures. Mark SVR in Estoril Blue Last edited by Mark_N on Sun Oct 25 2015 2:39am. Edited 1 time in total |
Sun Oct 25 2015 2:18am |
The SC and SVR are more performance orientated cars and are expected to make more noise when being worked hard. My SVR is very quiet and refined on a relaxed motorway cruise on a trailing throttle with the hooligan options turned off. Diesels run at higher compression ratios so there is a bigger bang at each cylinder detonation. It's that extra cylinder pressure which contributes to the noise and if LR have managed to tame it in normal driving, they've done a good job. The only diesel I've driven was at the Land Rover Experience in Eastnor Castle and it was a clattery old thing but that might have been down to its usage history. Mark SVR in Estoril Blue |
Sun Oct 25 2015 2:38am |
