![]() | Home > Technical > Suspension problems |
Frax Member Since: 07 May 2015 Location: Aberdeenshire Posts: 249 ![]() ![]() ![]() |
Can you clear them and see what comes back in Lot of Landcruisers now sold
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4526 ![]() ![]() ![]() |
I'd put a brake switch and 2 brake bulbs in the car |
Cosmo15555 Member Since: 24 Jun 2014 Location: Stevenage Posts: 163 ![]() ![]() ![]() |
I cleared the codes ok last night I will get a switch and bulbs today and fit
A lot of these alarms can be due to a battery not holding it's charge too. I would do Disco Mickey's checks that tail lights are working OK as this is the main cause of alarms in RRS1 and Disco3/4 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
I fitted new brake light switch
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 ![]() ![]() |
That's just what you're supposed not to do. ![]() 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver ![]() |
Fitting the switch the way I did has it damaged it |
I believe it may/will have. I have to say, I've never looked into, or thought about, why though |
B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420 ![]() ![]() ![]() |
I've just had the same warning message today too
I fitted a new switch on Monday and so far so good
Brill good to hear |
Fitted a new switch today without pressing the brake pedal but warning came back, all brake bulbs are working fine too, any ideas what to do next |
The Steering Angle Sensor (SAS) calibration sounds like a strong possibility. |
Check for +12v on the red wire going to the switch |
