Home > Technical > Suspension problems
Cosmo15555
United Kingdom 2010 Range Rover Sport Supercharged HSE Stornoway Grey
Suspension problems
I have had this happen a couple of times
Whilst driving lights on dash come on and warning in info display
Transmission fault
Special features disabled
Suspension lowered
I turn car off leave for a while then restart
Display's transmission fault
I have done code read these are the results
Audio Amplifier
B1A96-68 (2C) Bus still active after shutdown request - Algorithm based failure - event information
Body Control
B1B70-81 (2Cool Local interconnection network bus circuit 2 - Bus signal/message failure - invalid serial data received
Engine Petrol
P0504-64 (6Cool Brake switch A/B correlation - Algorithm based failure - signal plausibility failure
P0504-29 (6Cool Brake switch A/B correlation - General signal failure - signal is invalid
Transfer Case
U0132-86 (2Cool Lost communication with ride level control module - Bus signal/message failure - signal is invalid
U0155-87 (2Cool Lost communication with instrument cluster control module - Bus signal/message failure - missing a message
Vehicle Dynamic
C1A96-13 (0Cool Brake lamp switch circuit - General electrical failure - circuit open
C1A96-62 (0Cool Brake lamp switch circuit - Algorithm based failure - signal compare failure
Has anyone got any ideas
Thanks
Cosmo
Post #477571 Fri Oct 23 2015 7:16pm
Frax
Scotland 2012 Range Rover Sport SDV6 Autobiography Santorini Black
Can you clear them and see what comes back in Lot of Landcruisers now sold
Audi TT 240 Sport now sold for.
RRS 2.7 HSE Now sold for.
RRS Autoibiography 2012
Defender 300tdi 90
Post #477594 Sat Oct 24 2015 6:58am
Disco_Mikey
I'd put a brake switch and 2 brake bulbs in the car Thumbs Up
Very common issue Thumbs Up
Post #477595 Sat Oct 24 2015 8:13am
Cosmo15555
I cleared the codes ok last night I will get a switch and bulbs today and fit
I will also check for codes when I get home from work
Thanks for the replies
Cosmo
Post #477600 Sat Oct 24 2015 8:46am
Tim in Scotland
A lot of these alarms can be due to a battery not holding it's charge too. I would do Disco Mickey's checks that tail lights are working OK as this is the main cause of alarms in RRS1 and Disco3/4 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #477602 Sat Oct 24 2015 8:56am
Cosmo15555
I fitted new brake light switch
Pressed pedal down while fitting
Fitted new bulbs from Land Rover dealer
Drove car had same problem
These are the codes
Vehicle scanned on 24-10-2015 16:58
Using IIDTool BT V3.0 B1262
Engine Petrol
Vehicle Dynamic
C1A96-64 (0Cool Brake lamp switch circuit - Algorithm based failure - signal plausibility failure
A new battery was fitted about a year ago
Post #477641 Sat Oct 24 2015 5:05pm
Lost for Words
That's just what you're supposed not to do. Exclamation Visiting from DISCO3.CO.UK
Post #477644 Sat Oct 24 2015 5:28pm
Cosmo15555
Fitting the switch the way I did has it damaged it
Post #477669 Sat Oct 24 2015 10:43pm
Lost for Words
I believe it may/will have. I have to say, I've never looked into, or thought about, why though Question , but it is an observed effect. Thumbs Up Visiting from DISCO3.CO.UK
Post #477713 Sun Oct 25 2015 9:41am
B9BS X
I've just had the same warning message today too
Transmission fault
Suspension lowered
If I turn the car off then turn back on the message transmission fault appears but then car drives ok and if starting again no transmission message appear again.
But after driving a few miles up the road all the above warnings come back with a yellow exclamation mark flashing near the temp gauge Big Cry Big Cry Big Cry
Cosmo15555 - Did u find out what the fault was or was it all sorted after changing brake light switch? RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED,
BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR
Post #478230 Fri Oct 30 2015 2:00am
Cosmo15555
I fitted a new switch on Monday and so far so good
If you have a Brit part near you get switch from them as dealer is £25 and Brit part £11 so big difference in price for same item
I found this out after buying 2 switches as fitted first incorrect
Second time I fitted not moving brake pedal
Hope this helps
Cosmo
Post #478240 Fri Oct 30 2015 9:27am
B9BS X
Brill good to hear Thumbs Up
Im hoping ill be as lucky as you with this small fix as it was quite worriying when the warning messages came up while travelling down the motorway over 200 miles away from home Laughing RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #478260 Fri Oct 30 2015 12:09pm
B9BS X
Fitted a new switch today without pressing the brake pedal but warning came back, all brake bulbs are working fine too, any ideas what to do next Big Cry Big Cry Big Cry RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #478529 Mon Nov 02 2015 4:02pm
Lost for Words
The Steering Angle Sensor (SAS) calibration sounds like a strong possibility. Thumbs Up
Maybe worth changing the brake bulbs as a matter of course (make sure they're decent ones), as they can be fully functional, yet still be the culprit. Wink Visiting from DISCO3.CO.UK
Post #478530 Mon Nov 02 2015 4:08pm
Disco_Mikey
Check for +12v on the red wire going to the switch Thumbs Up
Post #478535 Mon Nov 02 2015 4:38pm
