Home > General > Would a 2010 steering wheel fit a 2007 RRS?
kungfupanda79
I've read some topics on the Internet to say that the later steering wheels would fit the earlier models if you swapped the airbag and switches over. Is this correct? I'm not bothered about adding steering wheel paddles.
Post #470146 Tue Aug 11 2015 11:43pm
Yes It can be done I did it to a 09plate pre-facelift car. Actually fitted Paddle Shift, Heated Steering Wheel and the ACC Control. However it was quite a expensive as I used all new part's which came from Dan at Duckworths and Colin from Blackbox Solutions and would of been in excess of 1k. Obviously if you second used hand parts it would be cheaper.
There are few post on here about it and a great deal more on the Disco Forum.
I have to admit it did look the part when done.
Post #470161 Wed Aug 12 2015 9:23am
kungfupanda79
Cheers for that Col.
Just to clarify, if I bought a 2010 steering wheel rim, I could swap over my current airbag and switches without a problem?
Post #470179 Wed Aug 12 2015 2:40pm
Hi
Air Bag Yes Switches No You will need new switches and the Circuit Boards from Blackbox Solutions.
Post #470181 Wed Aug 12 2015 3:08pm
Disco_Mikey
Done the same with my own D3. 2010 wheel with flappy paddles needs new circuit boards and flappy paddle kit.
There are extra kits for ACC and Heated functions Thumbs Up
Post #470182 Wed Aug 12 2015 3:37pm
kungfupanda79
Cheers for the advice guys. I was considering going for a Hawke piano black one which is at the clearance price of £139 however the cost of the new buttons and circuit boards would outweigh the savings so I might just stick with a 2005 replacement if needs be.
Post #470314 Thu Aug 13 2015 10:35pm
mgadel
Australia
Flappy paddle upgrade
is a new rotary coupler required when one fits flappy paddles RRS or D4
Regards Adrian
Post #479133 Sun Nov 08 2015 5:22pm
Disco_Mikey
No Thumbs Up
Post #479138 Sun Nov 08 2015 6:02pm
adam8matek
United States
I had similar problems but not solved very glad of this fact eko-bord big
Post #479208 Mon Nov 09 2015 2:39pm
