![]() | Home > General > Would a 2010 steering wheel fit a 2007 RRS? |
kungfupanda79 Member Since: 19 Oct 2011 Location: Manchester Posts: 72 ![]() ![]() |
I've read some topics on the Internet to say that the later steering wheels would fit the earlier models if you swapped the airbag and switches over. Is this correct? I'm not bothered about adding steering wheel paddles. |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5097 ![]() ![]() ![]() |
Yes It can be done I did it to a 09plate pre-facelift car. Actually fitted Paddle Shift, Heated Steering Wheel and the ACC Control. However it was quite a expensive as I used all new part's which came from Dan at Duckworths and Colin from Blackbox Solutions and would of been in excess of 1k. Obviously if you second used hand parts it would be cheaper.
Cheers for that Col.
Hi
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4507 ![]() ![]() ![]() |
Done the same with my own D3. 2010 wheel with flappy paddles needs new circuit boards and flappy paddle kit.
Cheers for the advice guys. I was considering going for a Hawke piano black one which is at the clearance price of £139 however the cost of the new buttons and circuit boards would outweigh the savings so I might just stick with a 2005 replacement if needs be. |
mgadel Member Since: 08 Nov 2015 Location: Adelaide Posts: 3 ![]() ![]() |
is a new rotary coupler required when one fits flappy paddles RRS or D4
No |
adam8matek Member Since: 09 Nov 2015 Location: new york Posts: 1 ![]() ![]() |
I had similar problems but not solved very glad of this fact eko-bord big |
