![]() | Home > Maintenance & Modifications > ACE anti roll bar bush |
| DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2026
Someone will be along soon to help you but good luck |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532
Yup, prop needs undone |
| DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240
OK, thanks for quick reply. How easy/difficult is taking off the prop. Do you know of a step by step thread on here that I could follow.
Any info, or pictures of course on how to get the prop shaft off the easiest way (if there is such a way) in order for me to access the three bolts on the passenger side to replace my anti roll bar bush. I believe this type of ACE anti roll bar bush with the three bolts is a bit trickier. Any takers |
Propshaft is held on with 6 bolts at either end.
Thanks DM but if I take six bolts off one end of the prop, are you sure that I will have enough room to move the prop out the way? If I go for taking the prop off altogether, what are the implications i.e. does it have anything that may fall out when I take prop out. Do I have to mark it so it goes back exactly how I take out. |
There is just enough room to get it out. It's easier if the shaft is right out the way. Undo the bolts, nothing to align or mark |
Cheers DM I will give it a go sometime soon. RRS 2.7 HSE Stornoway Grey
sorry before I start here as its a different issue regarding changing my rear brake pads.
Pistons lever back. Be careful not to bend the slide pins |
Great!! So take top of brake fluid reservoir then lever pistons apart, as you say no special tool required, should make this slightly easier. Cheers again |
Done and dusted over the weekend... rear pads/shoes on and adjusted... the decent weather made it not a bad job. No more horrible squealing EPB (for the meantime anyway) thanks for the help Disco_Mikey |
Hi,
Hi DM,
| All times are GMT |
