| RRSPORT.CO.UK | ||
|  | Home > Maintenance & Modifications > ACE anti roll bar bush |
| DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2025    | Someone will be along soon to help you but good luck   | ||
|  Mon Aug 10 2015 11:16am |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | Yup, prop needs undone | ||
|  Mon Aug 10 2015 3:26pm |
| DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240      | OK, thanks for quick reply. How easy/difficult is taking off the prop. Do you know of a step by step thread on here that I could follow.
|  Mon Aug 10 2015 3:42pm |
| DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240      | Any info, or pictures of course on how to get the prop shaft off the easiest way (if there is such a way) in order for me to access the three bolts on the passenger side to replace my anti roll bar bush. I believe this type of ACE anti roll bar bush with the three bolts is a bit trickier. Any takers   | ||
|  Tue Aug 18 2015 11:05am |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | Propshaft is held on with 6 bolts at either end.
|  Tue Aug 18 2015 12:30pm |
| DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240      | Thanks DM but if I take six bolts off one end of the prop, are you sure that I will have enough room to move the prop out the way? If I go for taking the prop off altogether, what are the implications i.e. does it have anything that may fall out when I take prop out. Do I have to mark it so it goes back exactly how I take out.   | ||
|  Tue Aug 18 2015 2:13pm |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | There is just enough room to get it out. It's easier if the shaft is right out the way. Undo the bolts, nothing to align or mark | ||
|  Tue Aug 18 2015 3:56pm |
| DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240      | Cheers DM I will give it a go sometime soon. RRS 2.7 HSE Stornoway Grey
|  Wed Aug 19 2015 7:53am |
| DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240      | sorry before I start here as its a different issue regarding changing my rear brake pads.
|  Thu Aug 20 2015 12:00pm |
| Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4532      | Pistons lever back. Be careful not to bend the slide pins   | ||
|  Thu Aug 20 2015 12:04pm |
| DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240      | Great!! So take top of brake fluid reservoir then lever pistons apart, as you say no special tool required, should make this slightly easier. Cheers again   | ||
|  Thu Aug 20 2015 12:13pm |
| DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240      | Done and dusted over the weekend... rear pads/shoes on and adjusted... the decent weather made it not a bad job. No more horrible squealing EPB (for the meantime anyway) thanks for the help Disco_Mikey   | ||
|  Mon Aug 24 2015 11:50am |
| DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240      | Hi,
|  Sun Sep 27 2015 1:38am |
| DerrekL Member Since: 23 Jul 2015 Location: West Lothian Posts: 240      | Hi DM,
|  Tue Oct 06 2015 2:24pm |
| Posting Rules
