Home > Maintenance & Modifications > Change front discs on Range Rover sport
MOLDY99
United Kingdom 2010 Range Rover Sport 3.0 TDV6 S Santorini Black
I changed the rear brake discs ok on my 2010 Range Rover sport... I now need to do the front ones. They should be easier than the rear as there is no complication of the electric handbrake.. Am I right? nice and simple or any surprises.
thanks
Post #469103 Sat Aug 01 2015 9:25am
fdhadi
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
I hope Bodsy's ok with me putting this on?
http://www.disco3.co.uk/gallery/thumbnails.php?album=4184
Post #469104 Sat Aug 01 2015 9:36am
MOLDY99
Thanks for the post but the guides seem to refer to The Discovery.... Regards
Post #469107 Sat Aug 01 2015 9:54am
Lost for Words
The (original) RRS is the same as a Discovery underneath. Wink
There are different brakes on the 3.0 vs the 2.7 as in the guide, but on the whole, the basics are the same. Obviously, a bit different again if you have Brembos, of course (I'm assuming you don't). Thumbs Up
As you say, no EPB to deal with on the front. Smile Visiting from DISCO3.CO.UK
Post #469108 Sat Aug 01 2015 10:05am
Bodsy
Site Sponsor
No problem using the bible. Thumbs Up
It doesn't cover front brembos, but is being updated soon, so if you (or anyone else) can take some brembo pics, I'll add it to the bible for future use by others. Thumbs Up
Istr it's just a couple of pins that come out and the retaining spring on the brembo setup? Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #469112 Sat Aug 01 2015 11:42am
kungfupanda79
Brembos are a lot easier to do than regular sliding caliper setups.
Post #470030 Mon Aug 10 2015 4:56pm
Pufftmw
Brembos are a doddle
There are 2 pins which are you need to knock out (I would suggest getting a centre-punch or a decent 3 inch nail). Do that by tapping them lightly on the side facing you with the tool of choice, then pulling out the other side with a pair of pliers. That releases the little spring plate that keeps the pads aligned. You can then use the pliers to pull out the pads.
If changing the pads, then I use the pads end on to push the calipers back (undo reservoir top first).
Reverse the process when putting back in. Pins just "clip" in when tapped from the other side and should be flush with the caliper when done. If done correctly, they'll never come out but it doesn't look like it.
Post #470044 Mon Aug 10 2015 6:21pm
