| RRSPORT.CO.UK | ||
|  | Home > General > Black smoke |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | Usual "starter for ten" is to check the intercooler hoses for splits. 2012 SDV6 - it's missing a couple of cylinders
|  Wed Jun 17 2015 7:53pm |
| Dazlar Member Since: 13 Apr 2015 Location: Gloucestershire Posts: 9      | Ok I'll check them and see if I can see anything..
|  Wed Jun 17 2015 7:57pm |
| Bodsy Site Sponsor Member Since: 03 Feb 2007 Location: Shropshire Posts: 2162    | Black smoke without the ESF is almost always a split in the intercooler hose or less likely a split in the intercooler itself. Bodsys Brake Bible
|  Wed Jun 17 2015 8:57pm |
| Dazlar Member Since: 13 Apr 2015 Location: Gloucestershire Posts: 9      | Thanks guys I've just been out to the car and found the split easy.. I don't know if it's the inter cooler hose but you might be able to help. It's at the front of the engine and goes of to left (drivers side) and is attached to a plastic thing with molded squares on it!!! ?? It's drops into the bottom of the engine can't see where it's attached down there, so must be a long hose????
|  Wed Jun 17 2015 9:31pm |
| Bodsy Site Sponsor Member Since: 03 Feb 2007 Location: Shropshire Posts: 2162    | That's the one. Easy to change.   | ||
|  Wed Jun 17 2015 9:36pm |
| Dazlar Member Since: 13 Apr 2015 Location: Gloucestershire Posts: 9      | Thanks very much gonna order on eBay now..👍👍
|  Wed Jun 17 2015 9:37pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | I think that's the one that comes up from the intercooler - the box with squares on connects to the front of the electronic throttle and has the charge air temperature sensor in it (to measure the temp of the air coming from the intercooler). 2012 SDV6 - it's missing a couple of cylinders
|  Wed Jun 17 2015 9:39pm |
| All times are GMT | < Previous Topic | Next Topic > |
| Posting Rules
