Home > General > Black smoke
Dazlar
Black smoke
Hi all..
Ha the rrs tdv6 2007 for a few months now with no problem. Went to France in it last week all good.. Just been up to Wales on a 400mile round trip just noticed on the way back whenever you tooch the accurate it's chucking out loads of smoke.. And The bottom off the square tips (autobiography conversion)are black with oil!!!!! Any body got any ideas or what I can check before taking it to the garage???
Thanks Darren
Post #464950 Wed Jun 17 2015 8:32pm
Usual "starter for ten" is to check the intercooler hoses for splits. 2012 SDV6 - it's missing a couple of cylinders
Post #464951 Wed Jun 17 2015 8:53pm
Dazlar
Ok I'll check them and see if I can see anything..
Cheers Darren
Post #464952 Wed Jun 17 2015 8:57pm
Bodsy
Site Sponsor
Black smoke without the ESF is almost always a split in the intercooler hose or less likely a split in the intercooler itself. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #464956 Wed Jun 17 2015 9:57pm
Dazlar
Thanks guys I've just been out to the car and found the split easy.. I don't know if it's the inter cooler hose but you might be able to help. It's at the front of the engine and goes of to left (drivers side) and is attached to a plastic thing with molded squares on it!!! ?? It's drops into the bottom of the engine can't see where it's attached down there, so must be a long hose????
Cheers Darren
Post #464961 Wed Jun 17 2015 10:31pm
Bodsy
Site Sponsor
That's the one. Easy to change. Thumbs Up Bodsys Brake Bible
See it HERE
Post #464962 Wed Jun 17 2015 10:36pm
Dazlar
Thanks very much gonna order on eBay now..👍👍
Darren
Post #464965 Wed Jun 17 2015 10:37pm
I think that's the one that comes up from the intercooler - the box with squares on connects to the front of the electronic throttle and has the charge air temperature sensor in it (to measure the temp of the air coming from the intercooler). 2012 SDV6 - it's missing a couple of cylinders
Post #464966 Wed Jun 17 2015 10:39pm
