![]() | Home > General > faulty air compressor range rover sport |
Might just be the end plate leaking. Someone on here sells a better replacement.....search forum |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9058 ![]() ![]() ![]() |
You can (or could) buy a refurb kit for the compressor too. About £80 from memory. 2012 SDV6 - it's missing a couple of cylinders
Brianb007 Member Since: 06 Jun 2015 Location: manchester Posts: 3 ![]() ![]() ![]() |
Hi thanks for your reply and advise.
LRS Engineering in Essex do the end cap too. See page 28 in current LRO magazine (free browsing in WHSmiths |
You need to know what the faults are before you can decide what to do with the ARB. If it's holding a fault code in the system then I doubt it's the bars themselves that are the problem. If a bar is leaking, it depends which bit is leaking as to how involved (and expensive) the fix is. 2012 SDV6 - it's missing a couple of cylinders
