Home > General > faulty air compressor range rover sport
Brianb007
Hi everyone looking for some advise please. I have a 2006 RRS 4.2 supercharged. Have a fault diagnosed by Land Rover which says Air compressor faulty requires new compressor. Also states possible fault with Ace system.
Firstly can the air suspension compressor be repaired rather than replaced ? any suggestions of repairers I live in Manchester. also any suggestions about Ace system. Thanks for your help.
Post #463902 Sat Jun 06 2015 11:44am
DrRob
Might just be the end plate leaking. Someone on here sells a better replacement.....search forum Thumbs Up
If it is the whole unit Censored then Britpart do a replacement one cheaper than LR. Paddocks spares probably sell them or John Craddocks or LR Direct or Island4x4 etc etc
http://www.britpart.com/parts/suspension-a...mpressors/ * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
I use www.glenrands.co.uk Great independent
Post #463905 Sat Jun 06 2015 1:50pm
You can (or could) buy a refurb kit for the compressor too. About £80 from memory. 2012 SDV6 - it's missing a couple of cylinders
Post #463912 Sat Jun 06 2015 4:42pm
Brianb007
Hi thanks for your reply and advise.
Assuming I can resolve the compressor fault what do I do about their comment saying faults also stored for Ace System may have further issues !!
From what I have read the Ace system could be very expensive £1000 + to repair.
Look forward to a reply.
Post #463924 Sat Jun 06 2015 7:48pm
DrRob
LRS Engineering in Essex do the end cap too. See page 28 in current LRO magazine (free browsing in WHSmiths Thumbs Up ) * Current. 2024 D350 Defender 90. Too many modern gimmicks on it !
Post #463939 Sun Jun 07 2015 8:32am
You need to know what the faults are before you can decide what to do with the ARB. If it's holding a fault code in the system then I doubt it's the bars themselves that are the problem. If a bar is leaking, it depends which bit is leaking as to how involved (and expensive) the fix is. 2012 SDV6 - it's missing a couple of cylinders
Post #463942 Sun Jun 07 2015 8:51am
