Home > General > 07 model year sat nav on the move [ question ]
Page 1 of 3 123>
The latest 07 sports will get sat nav on the move - ie enter postcodes whilst driving.... does anyone know if this will be available as on upgrade/software fix for our older sports Question
Mine is going in for its 1st service soon & if poss I would like to get this done.
Post #61747 Thu Oct 12 2006 10:57am
Don't see why not, if LR can be bothered to produce it.
Post #61748 Thu Oct 12 2006 11:02am
EXPIREDDATA
United Kingdom 2007 Range Rover Sport TDV8 HSE Rimini Red
This may be a silly question - but how does the old sat nav know that you are moving ? -
I assume it isnt relying on the GPS data.. RRS TDV8 HSE - Hybrid TV - Sunroof - Adaptive Front Headlights - Harman/Kardon LOGIC7 system
BMW GT
Post #61761 Thu Oct 12 2006 12:13pm
The ECU knows! 2005 Zambezi TDV6 - Gone but not forgotten
Post #61762 Thu Oct 12 2006 12:16pm
EXPIREDDATA
Very Annoyed wrote:
The ECU knows!
You'd hope so - but wouldnt it be simple to remove the connection between the ECU and the Satnav ? RRS TDV8 HSE - Hybrid TV - Sunroof - Adaptive Front Headlights - Harman/Kardon LOGIC7 system
BMW GT
Post #61769 Thu Oct 12 2006 12:38pm
Dont think you'll find its a simple connection????? Itls all software related/talk between all systems ecu/satnav/ignition/NASSA etc etc all connected via a system called "most" Confused
Post #61772 Thu Oct 12 2006 12:41pm
EXPIREDDATA wrote:
Very Annoyed wrote:
The ECU knows!
I would think this would confuse the system. The ecu knows how fast you're traveling linked in with the sat nav etc.etc. = position on map. 2005 Zambezi TDV6 - Gone but not forgotten
Post #61776 Thu Oct 12 2006 12:44pm
Or am I talking b Censored ks? 2005 Zambezi TDV6 - Gone but not forgotten
Post #61777 Thu Oct 12 2006 12:45pm
broomsticks Shocked
Post #61778 Thu Oct 12 2006 12:46pm
EXPIREDDATA
The ECU wouldnt get any speed from the satnav.
After all - GPS speed isnt accurate and is an average speed between two points.
I'm sure there must be an easy way to override this functionality... RRS TDV8 HSE - Hybrid TV - Sunroof - Adaptive Front Headlights - Harman/Kardon LOGIC7 system
BMW GT
Post #61789 Thu Oct 12 2006 1:16pm
The ECU gives it to the sat nav system. 2005 Zambezi TDV6 - Gone but not forgotten
Post #61790 Thu Oct 12 2006 1:25pm
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
The restriction on inputting or playing with the touch screen is speed related. You can still do it if rolling very slowly in Drive, so it is not gearbox switched.
In effect though all that happens is that certain screen controls are disabled. I would guess the vehicles speed is the trigger via the ECU to a simple screen function on/off affair and nothing to do with the actual Satnav system/disc etc.
I have NO idea how it could be disabled manually other than via a software hack, which is presumably how the dealers will do it, if they offer it as an option that is.
I have not yet found it to be an issue because you can still input previous addresses that are stored in the system when on the move. It's only when a brand new address is required that it's a problem. L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #61791 Thu Oct 12 2006 1:28pm
EXPIREDDATA
Why would it - The satnav can work out the speed using the GPS data.
It wouldnt be able to do anything with the data anyway. RRS TDV8 HSE - Hybrid TV - Sunroof - Adaptive Front Headlights - Harman/Kardon LOGIC7 system
BMW GT
Post #61792 Thu Oct 12 2006 1:29pm
EXPIREDDATA
Does Hybrid TV switch off when moving as well ? RRS TDV8 HSE - Hybrid TV - Sunroof - Adaptive Front Headlights - Harman/Kardon LOGIC7 system
BMW GT
Post #61794 Thu Oct 12 2006 1:31pm
tonser
Hi
When I picked up my 06MY TDV6 4 weeks ago, they told me they would be able to update the software for nav on the move - but only once they start shipping the 07MY cars, and are therefore issued with 07MY updates.
I spoke to the dealer yesterday and this still hasnt happened, but he hopes to have it int he nex month. They have also 'ordered' the lazy lock update from LR and are awaiting its arrival - not sure, but I guess they send these things out on disc ?
Tonse Play: '59 VW Kabrio & '90 964
Work: http://www.mustardpost.com
Post #61798 Thu Oct 12 2006 1:51pm
Page 1 of 3 123>
