![]() | Home > Maintenance & Modifications > Tow Eye Cover |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5139 ![]() ![]() ![]() |
Slightly Confused here, you say a Factory Fitted Overfinch Kit I assume you mean fitted by Overfinch as I'm sure L/R would not fit this at the factory. I have a 12 plate Autobiography, also a Overfinch GTS body kit in the garage to be fitted and there is no way the Autobiography tow eye cover will fit the Overfinch Bumper and I can't really understand why you would want to.
afzal.hussain Member Since: 22 Mar 2015 Location: London Posts: 2 ![]() ![]() ![]() |
Thanks Colin - by factory fitted, I meant fitted from new (purchased by overfinch when new and had the overfinch kit fitted, it's not really important). I have the standard overfinch kit (not the gts kit with the led's) and actually like the front tow eye cover you get on the autobiography kits.
