Home > Maintenance & Modifications > Tow Eye Cover
afzal.hussain
United Kingdom 2011 Range Rover Sport SDV6 HSE Fuji White
Tow Eye Cover
Hi all,
Completely new to this forum - purchased a range rover sport (61 plate) recently with a factory fitted overfinch kit from new. I was wondering if anyone is aware of whether the front tow eye cover which you get on the autobiography bodykits is compatible with the front bumper assembly of the overfinch kit?
Thanks in advance
Post #457896 Wed Apr 01 2015 3:28pm
Slightly Confused here, you say a Factory Fitted Overfinch Kit I assume you mean fitted by Overfinch as I'm sure L/R would not fit this at the factory. I have a 12 plate Autobiography, also a Overfinch GTS body kit in the garage to be fitted and there is no way the Autobiography tow eye cover will fit the Overfinch Bumper and I can't really understand why you would want to.
Post #457920 Wed Apr 01 2015 7:36pm
afzal.hussain
Thanks Colin - by factory fitted, I meant fitted from new (purchased by overfinch when new and had the overfinch kit fitted, it's not really important). I have the standard overfinch kit (not the gts kit with the led's) and actually like the front tow eye cover you get on the autobiography kits.
Thanks,
Afzal
Post #457927 Wed Apr 01 2015 8:09pm
