![]() | Home > Maintenance & Modifications > when i change the struts, shocks & airbags |
I've seen this happen with a very worn out shock absorber. Caused all sorts of problems, changed all the height sensors etc but was a worn out shock in the end. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9144 ![]() ![]() ![]() |
To answer the OP, the height sensors are mounted separately from the air suspension struts. You can change them separately. 2012 SDV6 - it's missing a couple of cylinders
