Home > Maintenance & Modifications > when i change the struts, shocks & airbags
hse-lee
so my shock absorbers are knackered x3 Big Cry
the car rides harder than my train does (literally i do actually drive a train) my question is this
when i put car into access mode it lowers down then raises up into extended mode, now i know this is common fault but could this be attributed to the shocks being worn out or more likely a height sensor, and as I'm replacing them in complete struts i.e. new strut with new shock and new airbag are the height sensors located on these struts or are they positioned elsewhere
cheers
lee
Post #454433 Mon Mar 02 2015 9:58pm
Bodsy
Site Sponsor
I've seen this happen with a very worn out shock absorber. Caused all sorts of problems, changed all the height sensors etc but was a worn out shock in the end. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #454442 Mon Mar 02 2015 10:54pm
To answer the OP, the height sensors are mounted separately from the air suspension struts. You can change them separately. 2012 SDV6 - it's missing a couple of cylinders
Post #454444 Mon Mar 02 2015 10:56pm
