![]() | Home > Technical > Question about access mode? How often? |
I use access mode all the time - IMO it should not cause premature wear on the components |
Hayden Member Since: 10 Nov 2013 Location: Isle of Wight Posts: 87 ![]() ![]() ![]() |
I always use access mode. just got used to pressing the button when parking,Think it looks a lot nicer. |
B9BS X Member Since: 19 Nov 2014 Location: Birmingham Posts: 420 ![]() ![]() ![]() |
Same here, I normally use it all the time, plus the beast LOOKS better when sitting lower down |
ravingmad Member Since: 23 May 2013 Location: Essex Posts: 331 ![]() ![]() ![]() |
I always use access mode when parking up for the night.
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 ![]() ![]() ![]() |
Never really bothered with it as it lowers itself anyway, as reguards to the compressor unsure on that one, plus the fact Ronnie Corbett is probably taller than me |
Gornal how do you get the car to lower itself, would like to add that option to my rrs |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9133 ![]() ![]() ![]() |
I never use access height - except for perhaps once a year when old folk need a lift. Off road height yes, access height no. |
To be honest I don't know, it does it itself when I lock it, but only when locked, if this makes sense ![]() |
Intersting, I thinks this is one to look into! |
FatJoe Member Since: 13 Dec 2014 Location: Staffordshire Posts: 259 ![]() ![]() ![]() |
Ive got side steps so the normal height isnt a problem for me. I just was curious as to what others did and whether not using it would either help maintain parts or whether it actually was worse by not being used. I'm not Fat. RRS TDV6 HST. |
riverblanche Member Since: 11 Jun 2011 Location: Retford'ish Posts: 1134 ![]() ![]() |
Hi
Third button to lower? I thought for that to work the haszards have to manually switched on? Which then defeats the point.
hi
I already have the FBH from Paul at Bas. Its great this time of year.
