Home > Technical > Question about access mode? How often?
FatJoe
United Kingdom 2006 Range Rover Sport TDV6 HST Java Black
Just curious here guys.
Do you all drop the RRS to access height everytime you want to get out the car or when its parked up at night?
Just wondered does the constant up and down put any wear on anything unnecessarily? Especially when I don't have a problem getting out the motor as it is. Its not too high in normal mode. I'm not Fat. RRS TDV6 HST.
Post #450678 Sun Feb 01 2015 11:59am
PEACHY
I use access mode all the time - IMO it should not cause premature wear on the components Thumbs Up 16MY Estoril Blue SVR.............
Post #450681 Sun Feb 01 2015 12:05pm
Hayden
United Kingdom 2013 Range Rover Sport SDV6 HSE Fuji White
I always use access mode. just got used to pressing the button when parking,Think it looks a lot nicer. Thumbs Up Think it may shorten the life of the compressor..
Post #450688 Sun Feb 01 2015 12:31pm
B9BS X
Same here, I normally use it all the time, plus the beast LOOKS better when sitting lower down Thumbs Up RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
EVERY POSSIBLE SOFTWARE UPDATE INCLUDING - BLUTOOTH UPDATE, SATNAV ON THE MOVE, CLOCK ON DASH, 3 CLICK FLASH, GEARBOX RESET, COMPRESSOR UPDATE AND SUSPENSION LOWERED,
BLACK CODE RE-MAPPED, AUTOBIOGRAPHY'D, NEW EXIDE BATTERY, NEW DENSO ALTERNATOR
Post #450689 Sun Feb 01 2015 12:46pm
ravingmad
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Santorini Black
I always use access mode when parking up for the night.
Just got into the habit of doing it. MY13.5 Autobiography, Santorini Black, Privacy Glass. Gone
Driving a milk float for now.
Post #450690 Sun Feb 01 2015 12:47pm
Gornal Hills
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
Never really bothered with it as it lowers itself anyway, as reguards to the compressor unsure on that one, plus the fact Ronnie Corbett is probably taller than me Whistle , Must say side steps help Thumbs Up 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #450691 Sun Feb 01 2015 12:54pm
B9BS X
Gornal how do you get the car to lower itself, would like to add that option to my rrs Very Happy RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #450692 Sun Feb 01 2015 12:58pm
I never use access height - except for perhaps once a year when old folk need a lift. Off road height yes, access height no. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #450695 Sun Feb 01 2015 1:13pm
Gornal Hills
To be honest I don't know, it does it itself when I lock it, but only when locked, if this makes sense Thumbs Up 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #450705 Sun Feb 01 2015 2:09pm
B9BS X
Intersting, I thinks this is one to look into! Mr. Green RRS SUPERCHARGED, 22 INCH ALLOYS, JAVA BLACK, FULLY COLOUR CODED
Post #450720 Sun Feb 01 2015 3:14pm
FatJoe
Ive got side steps so the normal height isnt a problem for me. I just was curious as to what others did and whether not using it would either help maintain parts or whether it actually was worse by not being used. I'm not Fat. RRS TDV6 HST.
Post #450764 Sun Feb 01 2015 5:28pm
riverblanche
Hi
swmbo always uses access mode every time she parks it up
I do if she is with me or she shouts at me Laughing
always put in access as we reverse into the garage though
don't think it should lower on its own overnight though Confused maybe after a few days yes... possible leak Question as for wear should not make a deal of difference as it has to work for every bump/corner
you can use the third button on the fob to lower the car, we have ours set for turning the lights on so if I ever get the FBH working right it will turn it as a pre-heater
Post #450776 Sun Feb 01 2015 6:51pm
FatJoe
Third button to lower? I thought for that to work the haszards have to manually switched on? Which then defeats the point.
I have a FBH so my third button is the warm up the car button Smile I'm not Fat. RRS TDV6 HST.
Post #450778 Sun Feb 01 2015 6:56pm
riverblanche
hi
can not remember which page in the handbook Rolling Eyes but you can set the third button to
put the headlights on (press again and think it will then put reverse lights on?)
open the rear hatch
open the rear glass
lower suspension to access mode
may be something else as well Question Smile
as for the turning the FBH on before opening the car if you have something like the BAS fbhic it works from turning the lights on ,
my plan is to start the fbh as I take the dogs for a walk in the morning by the time I get back ready to use the car the engine is nice and warm Cool
Post #450783 Sun Feb 01 2015 7:10pm
FatJoe
I already have the FBH from Paul at Bas. Its great this time of year.
Although the handbook regarding lowering the car only works if hazards are on. Read closer and you'll see Smile I'm not Fat. RRS TDV6 HST.
Post #450807 Sun Feb 01 2015 9:06pm
