![]() | Home > Technical > Any advice on judder when accelerating? |
Hamner Member Since: 28 Jan 2015 Location: Swansea Posts: 54 ![]() ![]() |
Hi to all - I am new to the forum and wonder if any of you could help.
hi thanks for reply would it be best to change the torque converter and give the gearbox flush a miss any idea cost to do this thanks for your help |
ACE 219 Member Since: 24 Jan 2015 Location: Isle Of Wight Posts: 27 ![]() ![]() ![]() |
The coat of a new torque converter from Vanmatic is about £450 inc vat. It's about 8 -10 hours labour to fit it. You'd fill the transmission with new oil at the same time. Total cost about £1000 |
hey thanks for that i will take a look into it a bit deeper |
FatJoe Member Since: 13 Dec 2014 Location: Staffordshire Posts: 259 ![]() ![]() ![]() |
Why not try a couple of tubes of this first?
hey hi joe that looks good have you had the problem aswell and did it work how many tubes will it take and wear does it go ha ha cheers |
No not had the problem however had a recent gearbox service and saw Disco Mikey and some other guys recomend to put this in as part of the gearbox service. I think they use it when they do a mega flush which I think is about £350.
cheers for that joe the judder is not to bad and only happens now and then just trying to sort out a few snags how do you find the hst version thanks Hamner |
If its only mild shudder a couple of tubes of that might help. A gearbox flush from Bodsy will deffinately help.
cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882 ![]() ![]() ![]() |
i have tried that in my gearbox and it did stop judder for a while but its not a permanent fix if gearbox has started to go wrong, do you have any warning lights like an f on dash |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4521 ![]() ![]() ![]() |
If you have a judder, an additive will mask the issues, but it's time to start saving for a gearbox rebuild...
Disco Mikey,
I would add, If you are not able to get it flushed, then you should at least change the gearbox oil a few times. e.g. Make the gearbox oil change part of your annual service In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Afraid I don't do gearbox flushes. ![]() Software Updates Contact me RRS Timed Heat/Remote kits - Contact me BAS Engine Re-maps/ EGR Blank EuIII and EuIV Clock On The Dash/ SNOTM /3Flash / BT Update /Service Reset/Error Codes read\ Gearbox Reset See it HERE |
