Home > Technical > Any advice on judder when accelerating?
Hamner
Wales
Hi to all - I am new to the forum and wonder if any of you could help.
I have a Range Rover Sport 2005 HSE. I have a judder when accelerating, especially uphill and reading through the forum people have had a mega gearbox flush that has solved the problem. Any thoughts please. Mileage is 108,000 approx and has never had a gearbox flush as far as I know.
Post #450109 Wed Jan 28 2015 8:18pm
ACE 219
A gearbox oil change (megaflush) can temporarily fix a judder but sometimes you'll need to change the torque converter for a perminant fix.
Post #450110 Wed Jan 28 2015 8:23pm
Hamner
Wales
hi thanks for reply would it be best to change the torque converter and give the gearbox flush a miss any idea cost to do this thanks for your help
Post #450112 Wed Jan 28 2015 8:35pm
ACE 219
The coat of a new torque converter from Vanmatic is about £450 inc vat. It's about 8 -10 hours labour to fit it. You'd fill the transmission with new oil at the same time. Total cost about £1000
Post #450117 Wed Jan 28 2015 9:02pm
Hamner
Wales
hey thanks for that i will take a look into it a bit deeper
Post #450120 Wed Jan 28 2015 9:13pm
FatJoe
United Kingdom 2006 Range Rover Sport TDV6 HST Java Black
Why not try a couple of tubes of this first?
http://pages.ebay.com/link/?nav=item.view&...1208561216 I'm not Fat. RRS TDV6 HST.
Post #450121 Wed Jan 28 2015 9:24pm
Hamner
Wales
hey hi joe that looks good have you had the problem aswell and did it work how many tubes will it take and wear does it go ha ha cheers Very Happy
Post #450124 Wed Jan 28 2015 9:37pm
FatJoe
No not had the problem however had a recent gearbox service and saw Disco Mikey and some other guys recomend to put this in as part of the gearbox service. I think they use it when they do a mega flush which I think is about £350.
Might work might not but worth a try. Depends how severe your shuddering is I supose.
Aparently easiest way to put it in is when gearbox is warm and up to temp. Running? Not sure.
Bodsy or Disco Mikey are the autobox experts on here. I'm not Fat. RRS TDV6 HST.
Post #450125 Wed Jan 28 2015 9:43pm
Hamner
Wales
cheers for that joe the judder is not to bad and only happens now and then just trying to sort out a few snags how do you find the hst version thanks Hamner
Post #450128 Wed Jan 28 2015 9:55pm
FatJoe
If its only mild shudder a couple of tubes of that might help. A gearbox flush from Bodsy will deffinately help.
Its great thanks, effectively just a HSE with a sunroof and Logic 7 I think Smile I much proffer the looks of the HST. My sort of style. I'm not Fat. RRS TDV6 HST.
Post #450131 Wed Jan 28 2015 10:22pm
cossiedave
England 2006 Range Rover Sport TDV6 Autobiography Zambezi Silver
i have tried that in my gearbox and it did stop judder for a while but its not a permanent fix if gearbox has started to go wrong, do you have any warning lights like an f on dash
Post #450144 Wed Jan 28 2015 11:35pm
Disco_Mikey
If you have a judder, an additive will mask the issues, but it's time to start saving for a gearbox rebuild...
These gearboxes should be flushed between 50-75k miles, depending on use. Any longer, and you will start causing irreparable damage to the box...
Post #450148 Wed Jan 28 2015 11:46pm
FatJoe
Disco Mikey,
My autobox had new oild and the filter I believe it is. Is that enough? It was done within the last 6 months at a garage. I'm not Fat. RRS TDV6 HST.
Post #450149 Wed Jan 28 2015 11:49pm
SRE
Spain
I would add, If you are not able to get it flushed, then you should at least change the gearbox oil a few times. e.g. Make the gearbox oil change part of your annual service In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #450175 Thu Jan 29 2015 10:32am
Bodsy
Site Sponsor
Afraid I don't do gearbox flushes. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #450180 Thu Jan 29 2015 10:52am
