Home > General > FBH fault when linked to my Hawkeye shows transmition fault.
Fritz
Germany 2006 Range Rover Sport TDV6 SE Java Black
Hi I am new to this and have tried to find somthing regarding this problem with no luck on RRS 2006 10057 Kms.
The original problem was I discoverd that the FBH was not working and with thick snow and -3 I guessed it should be!
So I connected my Hawkeye as you do and more or less the following happend.
Went into the 11 on the menu Fuel Burning Heater, then ticked all the questions. Then up came a whole lot of gear box faults both on the dash and on the Hawkeye. Then on the dash appeared the letter F.
Having reset everything the Gearbox is fine and changes as it should do.
It may be worth mentioning that last year I had a break light problem. Bad contact on the lefthand side which gave all the known falt codes. Contact cleaned 2 new bulbs and problem solved. This fault also showed transmition Problems!
Anyone any ideas?
Post #449590 Sat Jan 24 2015 2:15pm
Disco_Mikey
Did you use the CAN-BUS adaptor when trying to communicate with the FBH?
Post #449603 Sat Jan 24 2015 3:06pm
Fritz
No, I assume your refuring to the BA5080? Do I Need this then to gain access without getting all the errors being displayed? If so I will have to get one.
Do you have a idea what the problem could be with the FBH?
Post #449616 Sat Jan 24 2015 4:59pm
Disco_Mikey
Yes, you will.need the adaptor for the Hawkeye to switch between HS and MS CAN networks. Most of the systems are linked by HS CAN, but things such as FBH etc are all on the MS CAN network
Post #449617 Sat Jan 24 2015 5:05pm
Fritz
Thanks a lot, as Land Rovers are getting more popular here we could do with companys like yours.
It's alarming that without this the system can be put into such disorder without the CAN BUS.
Thanks again looks like another order to AEW Pad for the CAN BUS.
Post #449621 Sat Jan 24 2015 5:26pm
Disco_Mikey
It's easy when you know Thumbs Up
At least this part isn't too expensive Whistle
Post #449660 Sat Jan 24 2015 10:00pm
