Home > Faults & Fixes > TDV8 turbo failure !!
austencameron
car on start up went bang and would not fire up.
so trailered it to ramp ,took off turbo hose and full of oil.
lifted the body to investigate to find the other turbo had seized and snapped the shaft on the intake side.
found the shaft and nut in the pipe but no turbo vanes that are missing Sad
any help would be gratefully appreciated, I've flushed the intercooler but no vanes.
I am dreading having to remove the engine!...HELP
Post #449550 Sat Jan 24 2015 2:07am
Disco_Mikey
Last seized turbo I had on a TDV8 went with such a bang, it had blown the vanes all the way back up into the air box Shocked
Take it you have removed ALL of the turbo pipes to check for it, intake and boost pipes?
Post #449552 Sat Jan 24 2015 9:01am
austencameron
Hi mike
All pipes removed' and empty' no sign what so ever.
I'm hoping the vanes were fired backwards and out the exhaust some how.
Post #449610 Sat Jan 24 2015 4:18pm
Disco_Mikey
They wouldn't make it past the cat. If they managed to break through the cat, it should be in the centre silencer
Its not sounding good Big Cry
EDIT: Assuming we are talking.about the vanes on the intake side of the turbo, and not the exhaust side...
Post #449613 Sat Jan 24 2015 4:41pm
austencameron
intake side, the turbo is not broken down enough for them to go out the exhaust.... that was a long shot Big Cry
Post #449626 Sat Jan 24 2015 6:26pm
Disco_Mikey
I would be inclined to remove the Intercooler completely, and see if it is rattling loose inside the cooler. If not, same with the manifolds as far as is practical.
If there are no parts to be found, then they have either broken up over a period of time and been drawn through the engine gradually, or it has imploded, and been sucked into the engine...
Can you remove the exhaust, and check for any evidence in there
Post #449656 Sat Jan 24 2015 9:53pm
austencameron
Removed intercooler completely , flushed with brake cleaner, plenty oil but no vane traces, grrrr
Post #449691 Sun Jan 25 2015 10:36am
