Home > General > Flat battery / jump start
ilard
My car won't start, guessing flat battery due to sluggish turn over and dashboard lighting up like christmas tree. There's no way to jump start an automatic on a downhill is there? Crying or Very sad L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
RRS TDV6 HSE Lux (MY2011)... Nara Bronze / Arabica - now gone!
Post #449512 Fri Jan 23 2015 8:53pm
Andi
Nope, sorry mate.
Post #449513 Fri Jan 23 2015 8:55pm
ilard
I'll just have to wait for Green Flag.
I reckon it's in poor health, so I better order a replacement. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #449515 Fri Jan 23 2015 8:57pm
Bodsy
Site Sponsor
It was sluggish earlier. Do you have any battery charger to try? Or it could be on last legs as you mentioned. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #449516 Fri Jan 23 2015 8:58pm
ilard
I don't have any kit. I'll get Green Flag to start it and then get a new battery sorted.
It was all so much easier in the old days... just get a couple of guys to give you a push, lift the clutch and you chug into life! L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #449517 Fri Jan 23 2015 9:02pm
Bodsy
Site Sponsor
Given the relatively low use, I'd recommend getting a ctek charger. Either the msx5.0 or 7.0 or 10.0
All would be more than suitable for your needs and come with a connector lead you can leave connected to the car to make it easier to connect to for charging. Thumbs Up Bodsys Brake Bible
See it HERE
Post #449519 Fri Jan 23 2015 9:08pm
Agreed on the Ctek. I bought one recently and use it through the towing socket. If you don't have one of those, the Ctek comes with a choice of croc clips and ring connectors anyway so you can leave a quick release lead on the battery and just plug-and-go. You might want to order a Ctek extension lead if, like me, you want to have the Ctek in the garage whilst the vehicle sits outside on charge. It's 2m long and packs away to almost nothing. 2012 SDV6 - it's missing a couple of cylinders
Post #449682 Sun Jan 25 2015 8:59am
flydive
Re: Flat battery / jump start
In theory yes, but you need a long and steep downhill, need to get it at probably around 60-80 Kph. '08 RRS TDV8
Post #449683 Sun Jan 25 2015 9:42am
ilard
Well, I got my new battery and so I have been able to use the remote heat Bodsy enabled for me... And what a joy it is!!! Suddenly winter ain't so bad after all. Thumbs Up
I have not bought a ctek - I'm not sure how I coukd make this work as I only have on-street parking. There's no solar powered trickle chargers are there? Or maybe I could get a wind turbine. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #450653 Sun Feb 01 2015 9:10am
simple1
Halfords and others do a solar panel charger designed for caravans but works well on cars too. Plugs in to cigar lighter and trickles 0.5 amps which is plenty to keep battery topped up. Plenty on eBay too. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #450721 Sun Feb 01 2015 3:15pm
flydive
But you will have to modify the cigar lighter to be always on.
O r cut the plug and connect to the battery or the towing electrics(inside car) '08 RRS TDV8
Post #450727 Sun Feb 01 2015 3:49pm
simple1
Not the case when being back fed. I used one on my sport and wasn't a key near it. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #450728 Sun Feb 01 2015 3:55pm
flydive
Surprised to hear that, thought they were always disconnected, but nice to know.
Do all 3 cigar lighter work in reverse without key? '08 RRS TDV8
Post #450739 Sun Feb 01 2015 4:15pm
simple1
One in boot does not sure about the rest. I plugged mine in and sat it on roller blind. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #450742 Sun Feb 01 2015 4:27pm
flydive
Thanks Thumbs Up '08 RRS TDV8
Post #450750 Sun Feb 01 2015 4:45pm
