| RRSPORT.CO.UK | ||
|  | Home > General > Flat battery / jump start |
| Andi Member Since: 26 Jan 2014 Location: Here & There Posts: 263    | Nope, sorry mate. | ||
|  Fri Jan 23 2015 7:55pm |
| ilard Member Since: 20 Aug 2010 Location: London Posts: 975    | I'll just have to wait for Green Flag.
|  Fri Jan 23 2015 7:57pm |
| Bodsy Site Sponsor Member Since: 03 Feb 2007 Location: Shropshire Posts: 2162    | It was sluggish earlier. Do you have any battery charger to try? Or it could be on last legs as you mentioned.   | ||
|  Fri Jan 23 2015 7:58pm |
| ilard Member Since: 20 Aug 2010 Location: London Posts: 975    | I don't have any kit.  I'll get Green Flag to start it and then get a new battery sorted.
|  Fri Jan 23 2015 8:02pm |
| Bodsy Site Sponsor Member Since: 03 Feb 2007 Location: Shropshire Posts: 2162    | Given the relatively low use, I'd recommend getting a ctek charger. Either the msx5.0 or 7.0 or 10.0
|  Fri Jan 23 2015 8:08pm |
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9159      | Agreed on the Ctek. I bought one recently and use it through the towing socket. If you don't have one of those, the Ctek comes with a choice of croc clips and ring connectors anyway so you can leave a quick release lead on the battery and just plug-and-go. You might want to order a Ctek extension lead if, like me, you want to have the Ctek in the garage whilst the vehicle sits outside on charge. It's 2m long and packs away to almost nothing. 2012 SDV6 - it's missing a couple of cylinders
|  Sun Jan 25 2015 7:59am |
| flydive Member Since: 16 May 2007 Location: South Posts: 1213      |
 In theory yes, but you need a long and steep downhill, need to get it at probably around 60-80 Kph. '08 RRS TDV8 I converted my diesel RRS to run on an environmentally friendly mixture of caribou fat and baby seals oil | ||
|  Sun Jan 25 2015 8:42am |
| ilard Member Since: 20 Aug 2010 Location: London Posts: 975    | Well, I got my new battery and so I have been able to use the remote heat Bodsy enabled for me... And what a joy it is!!! Suddenly winter ain't so bad after all.   | ||
|  Sun Feb 01 2015 8:10am |
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657      | Halfords and others do a solar panel charger designed for caravans but works well on cars too. Plugs in to cigar lighter and trickles 0.5 amps which is plenty to keep battery topped up. Plenty on eBay too. 2x TDV6. SE and HSE. Both returned to sender with issues👀
|  Sun Feb 01 2015 2:15pm |
| flydive Member Since: 16 May 2007 Location: South Posts: 1213      | But you will have to modify the cigar lighter to be always on.
|  Sun Feb 01 2015 2:49pm |
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657      | Not the case when being back fed. I used one on my sport and wasn't a key near it. 2x TDV6. SE and HSE. Both returned to sender with issues👀
|  Sun Feb 01 2015 2:55pm |
| flydive Member Since: 16 May 2007 Location: South Posts: 1213      | Surprised to hear that, thought they were always disconnected, but nice to know.
|  Sun Feb 01 2015 3:15pm |
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657      | One in boot does not sure about the rest. I plugged mine in and sat it on roller blind. 2x TDV6. SE and HSE. Both returned to sender with issues👀
|  Sun Feb 01 2015 3:27pm |
| flydive Member Since: 16 May 2007 Location: South Posts: 1213      | Thanks  | ||
|  Sun Feb 01 2015 3:45pm |
| Posting Rules
