![]() | Home > Technical > Timed climate |
fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216 ![]() ![]() |
Were you stationary when you saw the option greyed out? It is disabled while driving so you don't get distracted trying to set the timer.
jeffhunt Member Since: 19 Oct 2014 Location: Hayling Island Posts: 83 ![]() ![]() |
I had a similar problem when I did mine.
myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433 ![]() ![]() |
Thanks fkarim and jeffhunt, all this helps me to learn.
I know that the manual heat options are greyed out if you turn the ignition on, you have to leave the start button alone, and just press the radio on button, they then appear (un-greyed out).
Spot on, I got the same information from GAP about 30 minutes ago but thanks anyway. The reason that I could see it in the menu sometimes and not at others is because sometimes I had the ignition on.
You can use the service function of the IID Tool for the FBH from the AHCM-auxillary heater control
It does, a lot. I'm on it. |
Glad to be of help, |
OK, it appears that my FBH is not working, the IID Tool shows me fault code:
Sorry to hear that its FUBAR'd,
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4521 ![]() ![]() ![]() |
Or even has a spare FBH in the shed |
Now you won't give me the easy fix solution - just kidding.
There is |
I mean is there an easy fix. Not "do you have a spare FBH". 😄 |
