Home > Technical > Timed climate
myfirstrrs
Timed climate
I activated timed climate last night using the IID Tool and all looked great. Set it to come on at 07:25 today and it didn't, when I went back into the option on the screen in the car it is visible but is now greyed out. Very frustrating.
Car has lots of diesel and battery seems fine.
Any ideas anyone?
Post #449072 Tue Jan 20 2015 8:36am
fkarim
Were you stationary when you saw the option greyed out? It is disabled while driving so you don't get distracted trying to set the timer.
Regarding it not coming on as programmed, I think you need to leave the heating on Auto when switching off the car. Not 100% sure if that is absolutely necessary - mine is always on auto aircon and timed climate & RPH just work unless when the battery is a bit low. Worth trying this anyway.
When it works, you are able to hear the FBH running before starting the car and the top light on the climate control dial flashes. Timed climate and RPH auto switch off after 20 minutes.
I vaguely remember I had to change 3 settings using IIDTool when enabling RPH but don't know about timed climate as it was already unlocked on mine. However, I would have thought if you can see the option on the screen and set the timer it can't be a CCF issue. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone
Gone: MY13 RRS 3.0 SDV6 HSE Black Edition, Orkney Grey/Ivory
Gone: MY09 RRS 2.7 TDV6 HSE, Santorini Black/Almond
Post #449077 Tue Jan 20 2015 10:26am
jeffhunt
I had a similar problem when I did mine.
As well as activating the timed climate you also have to change the fuel burning heater (FBH) from standard to Park Heating in the CCF, otherwise you get the icons on the screen but nothing happens when you set the timer.
If you have fitted the remote heating equipment that will ned to be activated separately also, HVAC Heat/Cool FBH Call start.
Hope this helps.
Jeff Thumbs Up
Post #449097 Tue Jan 20 2015 1:54pm
myfirstrrs
Thanks fkarim and jeffhunt, all this helps me to learn.
GAP have been great and sent me the following information:
IIDTool Menu->Car Config->HVAC Ventilation->FBH Call Start is equal to fitted radio This is the one related to the remote.
IIDTool Menu->Car Config->HVAC Ventilation ->Fuel Burning Heater is equal to fitted parking heat
IIDTool Menu->Car Config->HVAC Ventilation ->Timed Climate is equal to enable
After getting these three set correctly I could see the Timed Climate menu and set the time. Now it is visible but greyed out all the time. I have only tried it when parked, without the engine running but with the ignition on. Climate was set to Auto.
Any ideas anyone?
Post #449098 Tue Jan 20 2015 1:56pm
jeffhunt
I know that the manual heat options are greyed out if you turn the ignition on, you have to leave the start button alone, and just press the radio on button, they then appear (un-greyed out).
As for the timed climate, I've had no problems setting the timer and it activating.
Question I'll have a look around. If I find anything i'll get it up on here for you.
Post #449121 Tue Jan 20 2015 6:17pm
myfirstrrs
Spot on, I got the same information from GAP about 30 minutes ago but thanks anyway. The reason that I could see it in the menu sometimes and not at others is because sometimes I had the ignition on.
The problem now is that when I set the timer the FBH doesn't come on. I was pretty sure that the FBH was working with the engine running because I had a right stink in the cabin when the weather came cold, I though the car was on fire but it cleared after 20 minutes or so. Not so sure now. How can I test it?
Post #449129 Tue Jan 20 2015 7:34pm
jeffhunt
You can use the service function of the IID Tool for the FBH from the AHCM-auxillary heater control
Feature Supported
Auxiliary heater priming routine
Auxiliary heater operation check
Or you could have a look at the live values.
Are any fault codes showing?
This should (I think as I have not had to do it myself) prime the heater or start it depending on the option you choose. Worth a try.
Take a look here for all options.
http://www.gap-diagnostic.com/products/iidtool.html
Hope this helps.
Post #449132 Tue Jan 20 2015 7:47pm
myfirstrrs
It does, a lot. I'm on it.
Post #449133 Tue Jan 20 2015 7:49pm
jeffhunt
Glad to be of help, Thumbs Up
Let us know if you get it sorted..
Post #449134 Tue Jan 20 2015 7:54pm
myfirstrrs
OK, it appears that my FBH is not working, the IID Tool shows me fault code:
U3000-49 (6Cool Control module - System internal failure - internal electronic failure
Sounds like a trip to the dealer is needed as car is under warranty unless there is a reset option for this fault code. When I clear the code I still cannot get the FBH to fire up.
That thing above is actually 68 but looks funky.
Post #449169 Tue Jan 20 2015 9:38pm
jeffhunt
Sorry to hear that its FUBAR'd,
If no joy from the dealers give Bodsy or Disco_Mikey a PM, they know all about the FBH, and probably have a fix, or know a man who can.
Post #449173 Tue Jan 20 2015 9:59pm
Disco_Mikey
Or even has a spare FBH in the shed Whistle Thumbs Up
Post #449176 Tue Jan 20 2015 10:22pm
myfirstrrs
Now you won't give me the easy fix solution - just kidding.
Is there one by the way Disco_Mikey?
Post #449178 Tue Jan 20 2015 10:25pm
Disco_Mikey
There is Thumbs Up
Kept as a spare for my own car, but mine was kicked into life, and performed flawlessly since. Not that I am rubbing salt into a wound Embarassed
Post #449179 Tue Jan 20 2015 10:34pm
myfirstrrs
I mean is there an easy fix. Not "do you have a spare FBH". 😄
Post #449181 Tue Jan 20 2015 10:50pm
