Home > Maintenance & Modifications > service advice needed
jenko2005
Wales 2006 Range Rover Sport Supercharged Zambezi Silver
looking through my service book for my 4.2sc 2006 model its had the following services done
service A @ 3989 miles on the 9/3/2007
service B @ 7805 miles on the 20/3/2008
service A @ 14304 miles on the 25/6/2010
inspection 1 @ 18304 on the 16/12/2011
oil service @24736 on the 15/11/2012
oil service @34558 on the 25/02/2014
car has just turned 37,000 miles what is the next service ?
shall i take it to the stealers or an indy as i think the plugs, supercharger belt, brake fluid and coolant needs to be changed as well ?
any idea on costings or is my pants gonna be pulled down and a good rogering lol
Post #445538 Tue Dec 16 2014 6:02pm
simple1
It's 15000 miles and one year which ever comes first. You history looks like mine. 3-4000 miles between services although exactly 12 months apart. You are a half service short, seems to be 18 months between two. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #445559 Tue Dec 16 2014 8:05pm
jenko2005
Strastone's full service 105k miles plugs, supercharger belt,aux belt, brake fliud, coolant all in for £590 including vat
Post #445851 Fri Dec 19 2014 6:42pm
simple1
That sounds like good value when I was charged £408 for a 60,000 service on a TDV8 which only has filters and oils. Mind you the oil alone was over £100. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #445853 Fri Dec 19 2014 6:51pm
Paddi
Don't know the dealership; but if they are like all the others then once they have your car you will receive a 'phone call to tell you they have found all sorts of other expensive things that 'need doing sir'. Then your kecks come down.
The best thing to do (only my opinion of course) is let the dealer do the items you agreed to and then find a decent independent specialist and get their opinion on the necessity of the things that 'need doing'. You may have a nice surprise. 2008 MY Java Black TDV8 HSE
Post #445860 Fri Dec 19 2014 7:51pm
jenko2005
they can try to pull them down but wont get know where
Post #445867 Fri Dec 19 2014 10:14pm
Stuart
No reason to take an 06 car to a main dealer. Why pay daft money when it will add £0 value?
Just use a decent indy and don't obsess about intervals and mileages of olde.
Drop it in an indy any time in the next six to twelve months. You have only done 3k miles since the last one. No need to panic.
Post #445885 Sat Dec 20 2014 2:53am
R12345a
United Kingdom 2005 Range Rover Sport TDV6 SE Zermatt Silver
Stuart - I notice you're also in Manchester. Do you have any recommendations in terms of indys which you have had a good experience with?
Post #445948 Sat Dec 20 2014 8:55pm
Stuart
Land Ranger. Off Lancashire Hill in Stockport. Can be a bit of a wait to get in, but they are OK.
Also "Flack" here, is a mobile bloke from nearbyish, Preston or somewhere. He knows his eggs too and is a good guy who wont nail your hat on.
Post #445963 Sun Dec 21 2014 2:04am
Disco_Mikey
Get in touch with Flack. You won't be disappointed Thumbs Up
Post #445968 Sun Dec 21 2014 7:58am
jenko2005
Stuart the indy was £100 more expensive plus they wanted an additional £45 for brake fluid change and £40 plus the dreaded vat for coolant in this instant the main dealer come in cheaper
Post #445988 Sun Dec 21 2014 1:34pm
Disco_Mikey
Make sure you are comparing like-for-like servicing.
Was once told my service was £120 more than that of a main dealer, for a 7 year service.
I quoted for timing belts which should be done at 7 years, the dealer did not. They only quoted for an oil service. Thumbs Up
Post #446002 Sun Dec 21 2014 3:10pm
jenko2005
service went well no problems changed everything as agreed car feels much better
Post #446891 Wed Dec 31 2014 3:00pm
