![]() | Home > Technical > suspension playing up |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 ![]() ![]() ![]() |
If you've just had the turbo off have you cort a wire going to the connector blocks behind the n/s/f wheel arch liner ? Do the fault codes give you any clues ?
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 ![]() ![]() |
i took the arch liner off again to check that but all seems ok,weres the steering angle sensor |
The steering angle sensor is on the steering colume and you can recal using diag equipment like hawkeye etc. they can cause things like the sus to drop the dash normally lights up like a Christmas tree, I just thought it was worth trying.. 2008 G4 RRSport TDV8 current
had suspension compressor bench tested today and its good as new so that rules that one out,would a ride hight sensor cause this problem as thats the only thing i have touched /disconected silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Come on fellas some one must have an idea |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4518 ![]() ![]() ![]() |
Need your fault codes read, otherwise you are |
k mate tomorrow |
quick update,when i fitted near side height sensor it wasnt quite sitting in its bracket properly |
panda Member Since: 17 Jan 2010 Location: london Posts: 702 ![]() ![]() |
Won't do that again will you! |
No mate. This car has aged me ten years |
