Home > Technical > suspension playing up
gazzc
2005 Range Rover Sport TDV6 HSE Siberian Silver
Orange suspension light coming on Norma height only. Then red light max speed 30mph..last sport I needed a new compressor. But only orange light was coming on not red...any ideas silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Rimini red rrs 2.7 tdv6 steps. Full c code. Recon engine!!loved but!gone ,thank god !!
Gone rr sport supercharged. Loved but 11mpg !!!
current,triumph stag mk2...current bmw 325 sport convertible
Post #424303 Wed May 14 2014 8:08pm
Camelrock
If you've just had the turbo off have you cort a wire going to the connector blocks behind the n/s/f wheel arch liner ? Do the fault codes give you any clues ?
Might be worth checking steering angle sensor is set correctly.
Good luck 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #424329 Wed May 14 2014 10:45pm
gazzc
i took the arch liner off again to check that but all seems ok,weres the steering angle sensor Question silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #424341 Thu May 15 2014 6:18am
Camelrock
The steering angle sensor is on the steering colume and you can recal using diag equipment like hawkeye etc. they can cause things like the sus to drop the dash normally lights up like a Christmas tree, I just thought it was worth trying.. 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #424386 Thu May 15 2014 1:13pm
gazzc
had suspension compressor bench tested today and its good as new so that rules that one out,would a ride hight sensor cause this problem as thats the only thing i have touched /disconected silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #424425 Thu May 15 2014 6:15pm
gazzc
Come on fellas some one must have an idea Crying or Very sad silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #424446 Thu May 15 2014 8:56pm
Disco_Mikey
Need your fault codes read, otherwise you are Censored into the wind. Could be 1 out of 100 things causing the light to come on...
Post #424449 Thu May 15 2014 9:05pm
gazzc
k mate tomorrow Thumbs Up silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #424453 Thu May 15 2014 9:38pm
gazzc
quick update,when i fitted near side height sensor it wasnt quite sitting in its bracket properly Embarassed cant believe it caused me all that grief Rolling Eyes silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #424574 Sat May 17 2014 6:33pm
panda
Won't do that again will you! Thumbs Up Thumbs Up
Post #424575 Sat May 17 2014 6:38pm
gazzc
No mate. This car has aged me ten years Rolling with laughter silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Post #424589 Sat May 17 2014 9:08pm
