![]() | Home > Maintenance & Modifications > tdv8 starter motor |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4484 ![]() ![]() ![]() |
IIRC, it's a |
range17 Member Since: 08 Oct 2012 Location: bedford Posts: 109 ![]() ![]() ![]() |
Think it is messing me about ,clicks a few times then works ,want to check connections on it ,not sure where to
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9076 ![]() ![]() ![]() |
Mine did that for a while. Then it died. 2012 SDV6 - it's missing a couple of cylinders
Did you replace it yourself ? zx12r
No, I had it done by the dealer under warranty. 2012 SDV6 - it's missing a couple of cylinders
ok thanks zx12r
Mark_TDV8 Member Since: 17 Nov 2013 Location: West Sussex Posts: 42 ![]() ![]() ![]() |
Was the starter itself clicking, or did you get no response when turning the key?
Yes starter was clicking ,when I try for second /third time it starts fine ,I am thinking its the solenoid sticking,
Sorry, not done it - trying to diagnose a fault on my own truck. mine doesn't click, it just doesn't do anything when you turn the key sometimes. I suspect mine is just a loose or wet connection on the starter solenoid...
Sorry to hear that for you ,I am looking at mine this lunch time and hopefully changing it soon ,if so I will
Cheers - will be interested to hear how you get on. Good luck... 2007 TDV8 RR Sport HSE
Looking at the workshop manual, the job does look, as Mikey suggested, to be a |
Yes i agree had the skid plate off yesterday and was able to see the motor ...just !!
You have a PM |
