Home > Maintenance & Modifications > tdv8 starter motor
Page 1 of 3 123>
range17
tdv8 starter motor
Hi ,does anyone know what sort of job it is to change the starter motor on my tdv8 .
Thanks Rob zx12r
bmw gs1200 adventure
defender 90 off roader
Post #415674 Wed Feb 26 2014 10:46pm
Disco_Mikey
IIRC, it's a Censored of a job
Post #415679 Wed Feb 26 2014 11:07pm
range17
Think it is messing me about ,clicks a few times then works ,want to check connections on it ,not sure where to
gain access to it from yet . zx12r
Post #415685 Wed Feb 26 2014 11:21pm
Mine did that for a while. Then it died. 2012 SDV6 - it's missing a couple of cylinders
Post #415697 Thu Feb 27 2014 12:47am
range17
Did you replace it yourself ? zx12r
Post #415709 Thu Feb 27 2014 7:38am
No, I had it done by the dealer under warranty. 2012 SDV6 - it's missing a couple of cylinders
Post #415730 Thu Feb 27 2014 11:02am
range17
ok thanks zx12r
Post #415732 Thu Feb 27 2014 11:08am
Mark_TDV8
England 2007 Range Rover Sport TDV8 HSE Cairns Blue
Was the starter itself clicking, or did you get no response when turning the key?
Thanks
Mark 2007 TDV8 RR Sport HSE
2003 TD5 Discovery 2 ES
2001 TD5 Defender 110 DCPU
2003 4.4 RR Vogue [Project]
Post #415740 Thu Feb 27 2014 12:15pm
range17
Yes starter was clicking ,when I try for second /third time it starts fine ,I am thinking its the solenoid sticking,
just trying to find someone that has actually done one to see what sort of job it is zx12r
Post #415750 Thu Feb 27 2014 12:54pm
Mark_TDV8
Sorry, not done it - trying to diagnose a fault on my own truck. mine doesn't click, it just doesn't do anything when you turn the key sometimes. I suspect mine is just a loose or wet connection on the starter solenoid...
Post #415753 Thu Feb 27 2014 1:01pm
range17
Sorry to hear that for you ,I am looking at mine this lunch time and hopefully changing it soon ,if so I will
let you know what job it was zx12r
Post #415755 Thu Feb 27 2014 1:03pm
Mark_TDV8
Cheers - will be interested to hear how you get on. Good luck... 2007 TDV8 RR Sport HSE
Post #415756 Thu Feb 27 2014 1:05pm
Looking at the workshop manual, the job does look, as Mikey suggested, to be a Censored 2012 SDV6 - it's missing a couple of cylinders
Post #415894 Fri Feb 28 2014 12:04am
range17
Yes i agree had the skid plate off yesterday and was able to see the motor ...just !!
going to have to take a couple more covers off to gain access,even then it will
be tricky .
My local independent wanted £400 plus price of starter ! so i will do it myself thankyou Shocked zx12r
Post #415903 Fri Feb 28 2014 7:51am
You have a PM Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #415952 Fri Feb 28 2014 7:06pm
Page 1 of 3 123>
