![]() | Home > Technical > 2 stroke oil in diesel tank tdv6 ?? |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
70 pages for a quick browse on the subject |
gazzc Member Since: 07 Jan 2010 Location: cheshire Posts: 494 ![]() ![]() |
Thanks Nick .impressive silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
Saeedasghar Member Since: 11 Dec 2012 Location: Worcester Posts: 104 ![]() ![]() |
There was a big topic on here in regards to the 2 stroke question. My end decision was its better to use high quality fuel and additives such as redex, forte, millers........ with no risk to internal parts or seals. Then risk adding 2 stroke to knacker anything up. Hope this helps |
Really can I ask what made u against the 2 stroke oil option as the write up seems so good.thanks for reply.garry silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9133 ![]() ![]() ![]() |
The whole 2 stroke debate seems to polarise in to two camps: those that ask for proper evidence of its efficacy and those who just say "I did it after reading about it on the internet and I think my engine is quieter so it must be great".
ok thanks for reply,not sure if i will bother now silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
In my opinion,as a qualified design engineer, good quality fuel and good quality oils changed regularly is the best route. Drive with some mechanical sympathy - let it fully warm up before using maximum performance and let it idle for a few seconds before switching off. |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 ![]() ![]() ![]() |
I think I would be concerned about a build up of carbon deposits from adding two-stroke oil, rather than the reverse (I haven`t read the report by the way), also, I would have thought extra lubricating oil in the top-end of the engine (some of which contain metallic additive packs) may well damage the oxidation catalyst in the exhaust and certainly will contaminate the diesel particulate filter on Euro 5 engines.
The problem is that many of the opinions and suggestions found on the 'Web' are unsubstantiated and the vested interests and/or the qualifications of those posting aren't usually open to scrutiny. I've not seen any objective and controlled tests from reputable laboratories.
thats that idea sacked then |
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 ![]() ![]() ![]() |
I have used FC two stroke in my LR3, RRS, BMW X5 and Fiat Ducato Motor home, all bought new and in the case of the LR3 for 5 years since its purchase in 2006 and sale in 2011. X5 from 2006 and still have and it gets its dose at every fill.
is there any specific 2so or can you add any brand silverRRS 2.7 TDV6 22"WHEELS FULL COLOUR CODE,STEPS,REMAP..gone
2 stroke has various standards applied to it, I use FC but others are happy with FB.
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1942 ![]() ![]() ![]() |
What ratio 2 stroke to fuel do you use Barry? Gone - 2008 Stornoway Grey RRS 2.7 TDV6
