![]() | Home > General > NEED HELP PLEASE... Gearbox / transmission noise !? |
| simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657
Sounds very similar to the noise I had in my Sport after the monkey who replaced the engine forgot to do up the bolts on the torque converter. |
| shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 441
The rasping noise could be due to belt tensioner, sometimes makes strange noises at higher speeds, also could contribute to the heavy steering. I had intermittant heavy steering on my sc. I had the aux belts changed as part of the service and steering has been perfect ever since. |
| Gbooi Member Since: 22 Dec 2013 Location: Arnhem Posts: 4
thanks for the answers for so far..
| Paddi Member Since: 06 Jul 2012 Location: Hertfordshire Posts: 1563
One of our expert contributors has previously advised that stiff steering is frequently caused by a partially seized lower universal joint in the steering column and the fix is to change for a new part at a cost of approx Ł60. Worth investigating?
| ACE 219 Member Since: 24 Jan 2015 Location: Isle Of Wight Posts: 27
My RRS makes this noise.
| All times are GMT |
