![]() | Home > General > NEED HELP PLEASE... Gearbox / transmission noise !? |
Sounds very similar to the noise I had in my Sport after the monkey who replaced the engine forgot to do up the bolts on the torque converter. |
shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 441 ![]() ![]() ![]() |
The rasping noise could be due to belt tensioner, sometimes makes strange noises at higher speeds, also could contribute to the heavy steering. I had intermittant heavy steering on my sc. I had the aux belts changed as part of the service and steering has been perfect ever since. |
Gbooi Member Since: 22 Dec 2013 Location: Arnhem Posts: 4 ![]() ![]() ![]() |
thanks for the answers for so far..
One of our expert contributors has previously advised that stiff steering is frequently caused by a partially seized lower universal joint in the steering column and the fix is to change for a new part at a cost of approx Ł60. Worth investigating?
ACE 219 Member Since: 24 Jan 2015 Location: Isle Of Wight Posts: 27 ![]() ![]() ![]() |
My RRS makes this noise.
